1Back to top Go down   K100/K1100 Handlebar Switchgear etc. Empty K100/K1100 Handlebar Switchgear etc. Wed Apr 29, 2015 12:29 pm
krambo
krambo
Can anybody confirm that the left hand side switchgear assembly is the same on the K100 series as that on the K1100 series ?  I have a broken switch assembly on my K100 and was hoping to swap it with the switch off my non-running K1100 in order to restore headlight/turn signal/horn functionality.  Looking at the parts list on Moto Bins the parts look to be the same for both.  Any replies/thoughts would be welcomed from our knowledgeable members Surprised
"Aut viam inveniam aut faciam." K100/K1100 Handlebar Switchgear etc. Uk-bmw12
http://www.its-personal.net
mike d
Just had a quick look on the MAXBMW parts list site.
May depend on the year of your bikes:
K100 years 07/90 to 01/92 part number is 61312305231
K1100 to 08/95 uses the same part number.
K1100 from 08/95 uses 61312306058
The earlier K100 also use a different part number.
Mike
Last edited by mike d on Wed Apr 29, 2015 2:49 pm; edited 1 time in total (Reason for editing : Missed last digit of the K100 part number.)
krambo
krambo
mike d wrote:Just had a quick look on the MAXBMW parts list site.
Mike
Thanks for the response Mike. My K1100 is 1993, the K100 is 1984 so................ ?
2V and 4V models have different connectors.
krambo
krambo
Inge K. wrote:2V and 4V models have different connectors.
Thanks for that Inge K.  I do know of a K100 breaking locally but not sure what year it is.  Could the connections be modified easily to enable the switch from the K1100 to work for me ?  I'm not good with vehicle electrics Sad
I think you'd need to replace the connectors on both sides for a matching pair. It's a colour-for-colour match, so getting the wires right wouldn't be a problem. Not unless your LT switch has the powered screen controls, but from your original post I don't think that's the case? Should be just seven wires in either connector.
krambo
krambo
Dai wrote:I think you'd need to replace the connectors on both sides for a matching pair. It's a colour-for-colour match, so getting the wires right wouldn't be a problem. Not unless your LT switch has the powered screen controls, but from your original post I don't think that's the case? Should be just seven wires in either connector.
Thank you for the input - the electric screen switch for my K1100 is actually a seperate switch in the centre handlebar console and not part of the left hand switchgear.
krambo wrote: I do know of a K100 breaking locally but not sure what year it is.
It's a rather good chance that it is the type that you are looking for, as the
only K100 model with the other type of connector is RS16V (-90 -92).
krambo
krambo
Thanks again for your valued input Inge K.
krambo
krambo
Well, I spoke to the local owner of the "breaking" K100 and he has told me that I am welcome to take the switchgear and try it out.  We have also come to an arrangement whereby the non-running K1100 will go and live in one of his sheds.  I will update evryone on my progress as and when....... Smile
