1Back to top Go down   Broken Panniers! Empty Broken Panniers! on Sun May 03, 2015 8:02 pm
rebelredK
rebelredK
Hi, I bought my K100rt in January, and the latches (which do NOT have key locks) on each of the panniers broke, looks like they were rarely opened and the metal parts cracked. The bike is a 1985 model, and the boxes are original BMW touring... any ideas on replacing them ? TheBMW dealer wants a lot for replacements, which have keys, but look the same size....or maybe somebody has a set to offer ??
1985 K100RT Red 98k miles
1983 Honda CB650sc Nighthawk (sold)
"Born to Ride...Forced to Drive!"
2Back to top Go down   Broken Panniers! Empty Broken panniers on Mon May 04, 2015 9:53 am
td5
td5
Here you go
Locks
Hope this helps
TD5
3Back to top Go down   Broken Panniers! Empty Re: Broken Panniers! on Mon May 04, 2015 11:03 am
Both types of latches simply rivet to the panniers. The earlier type use a lift-up rectangular lid over the keyhole and a simpler key while the later version use a traditional key - the same type as your ignition - which can be matched by a less than clever locksmith. The superior later type will retro to the early type pannier and will, of course, cost more initially. TD5's link shows both for comparo purposes.
I'm practicing social media distancing; no Facecrack, Wazzup or Instagreedy!
1970 R60/5, '77 R75/7-R100, '85 K100'87 K75C, '87 K100RS, '93 K11-K12 Big Block, '93 K1100RS, '95 R100-Mystic, '96 K1100RS, '98 K1200RS, '00 K1200RS, '02 K1200RS, '03 K1200GT, '04 R1150R'04 R1150RT, '05 K1200S, '06 K1200R, '07 K1200R, '09 K1300GT & 2013 R1200RT-Polizia  - the Beemers in my life I can recall, owned still or sold on, since 1976.
4Back to top Go down   Broken Panniers! Empty Re: Broken Panniers! on Wed May 06, 2015 5:48 am
rebelredK
rebelredK
@td5 wrote:Here you go
Locks
Hope this helps
TD5
Thanks td5, that will do the job!!
5Back to top Go down   Broken Panniers! Empty Re: Broken Panniers! on Wed May 06, 2015 5:50 am
rebelredK
rebelredK
@Two Wheels Better wrote:Both types of latches simply rivet to the panniers. The earlier type use a lift-up rectangular lid over the keyhole and a simpler key while the later version use a traditional key - the same type as your ignition - which can be matched by a less than clever locksmith. The superior later type will retro to the early type pannier and will, of course, cost more initially. TD5's link shows both for comparo purposes.
Thanks, no keys on mine but td5's link will sort it out :-)
6Back to top Go down   Broken Panniers! Empty Re: Broken Panniers! on Wed May 06, 2015 5:56 am
Hi Mark
I was down your way yesterday evening but didn't see the bike parked outside- I called in to see if the panniers were on it.
There are a few sets of panniers around in the Eccentrics, we might be able to sort something.
Olaf.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 102,500 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell Now 36,188  miles
7Back to top Go down   Broken Panniers! Empty Re: Broken Panniers! on Thu May 07, 2015 8:21 am
rebelredK
rebelredK
@92KK 84WW Olaf wrote:Hi Mark
Olaf.
I can't lock the panniers so they are sitting on my floor at the mo, but I think a replacement set would be best as the work and cost to replace 4 locks won't be worth it, but I'd like to see what's out there :-)
O
8Back to top Go down   Broken Panniers! Empty Re: Broken Panniers! on Thu May 21, 2015 7:43 pm
mawhera
mawhera
I have purchased all the bits, hinges and locks with keys from Motobins UK. Mine were broken in and off on the grass Burt Munro Rally camping ground as well as the plastic pannier, broken in 3, which I got successfully plastic welded up. Duck tape got me home. Broken Panniers! Alien
mawhera Rick K IWI tours New Zealand
Broken Panniers! Nz_log10
Rick
K IWI land
New Zealand
