1Back to top Go down   Wire plug connections Karamba Empty Wire plug connections Karamba on Wed May 13, 2015 12:20 am
gladstone sa old fart
I have lost my diagrams I downloaded for to make the connection from computer to bike
Can anyone point me to a copy please ?
I have the software installed, just need to make up the plug & wires.
Thanks in-advance if I forget to get back to you
Peter J
http://pjingladstonesa.blogspot.com
2Back to top Go down   Wire plug connections Karamba Empty Re: Wire plug connections Karamba on Wed May 13, 2015 1:59 am
All I ever do is use a 3.5mm plug for 2 wires and connect the wires to the speedo connector behind the right side cover and plug the plug into the sound outlet on the laptop then run the program.
I used to have trouble making things work with the old laptop because the signal was weak so I put it through some speakers with an amplifier and a 3.5mm jack to the bike.
Have a look here Duck did a how to that can help but it is mainly if the speedo is off the bike http://classickbikes.com/ckb.tech/0.ckb.tech.files/speedocal/speedocal.htm
3Back to top Go down   Wire plug connections Karamba Empty Re: Wire plug connections Karamba on Wed May 13, 2015 8:29 am
Karamba tutorial has pictures of the adapter cable you need to make.
4Back to top Go down   Wire plug connections Karamba Empty Karumba on Wed May 13, 2015 9:08 pm
Thank you, I found that late yesterday, it is what I was looking for.
Peter J
