1 Help with swing arm pivot plate removal Thu May 14, 2015 12:55 am
audibob
I am removing my swing arm to replace a split boot cover, and I need some advice on how to remove the fixed pivot plate without damaging anything. It seems reluctant to move . Do I make a tool with stubs to fit in each hole and turn the plate, or can I use a drift through the bearing from the nearside and remove it that way.Would doing this remove the bearing too if the stub shaft was tight on the bearing inner race.
Are the bearings easy to remove as I might like to do them whilst everything is apart.
Thanks for any replies.
Bob
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
