You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    two piece mudguard on Wed Jun 03, 2015 7:59 pm
smoll1
Very Happy Hi all
I have a quick question that hopefully someone will know. I have k100 with two piece mudguard, i had cut the long bolt that goes through the fork bridge/brace. I have looked on bmw fische but it does not mention length. Does anyone know what length the bolt that holds the two mudguard pieces together is ? I can then near the end of my 4 year restoration hooray:DU
2Back to top Go down    Re: two piece mudguard on Thu Jun 04, 2015 5:31 am
Every catalogue I have a squiz at, including ETK, realoem, etc., shows it to be a discontinued part with zero reference. I don't have any older info to look at. I'd just measure the distance 'tween the two halves over the black centre section and punt.
'77 R75/7-1000cc, '87 K100RS, '93 w/K12 Big Block, '94 R100 Mystic, '03 K1200GT, '04 R1150RT, '06 K1200R, '07 K1200R & '09 K1300GT
3Back to top Go down    Re: two piece mudguard on Thu Jun 04, 2015 10:49 am
JGT
I replaced my bolt with a length of studding and a nut at the rear. No more dismantling problems. John
1987 K75s 1969 Bultaco Matador
4Back to top Go down    bolt on Thu Jun 04, 2015 5:43 pm
smoll1
Thanks guys
I measured the gap about 100mm so order bolt slightly longer and cut to size. Good idea on stud had look in shed and only had m8 and m10 oh well
