1Back to top Go down   Replacement side panel Empty Replacement side panel Sat Jun 06, 2015 10:45 am
TheJoker
TheJoker
Don't know how it happened but my right hand side panel has gone missing it only had 2 bungs on it and didn't have the clip that went behind the rear fairing. Anyway my bike is a silver k100RS (84).
Can't really find any side panels in silver, however I'm thinking of just getting any old side panel. However is there any difference between the years Question
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
2Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sat Jun 06, 2015 10:58 am
You must look for a cover from a -83 to -85 year model.
3Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sat Jun 06, 2015 4:02 pm
Also, forget trying to get one with an intact lower bracket (from your description I think yours might have been missing anyway). I'm talking about the one that slides over the spike welded to the tube down to the gearbox. It's easy enough to fabricate your own to do the job. I bent up two L-brackets out of thin alloy and bolted them to the side-panel with two 3mm screws. With hindsight, I could have used only one. Another way would be just to glue the new bracket to the back of the sidepanel. Thick plastic card would do the job too.
4Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sat Jun 06, 2015 4:50 pm
TheJoker
TheJoker
@Inge K. wrote:You must look for a cover from a -83 to -85 year model.
Damn that's what I feared guess I've stumbled upon the rocking horse part at the moment for this bike.
@Dai wrote:Also, forget trying to get one with an intact lower bracket (from your description I think yours might have been missing anyway). I'm talking about the one that slides over the spike welded to the tube down to the gearbox. It's easy enough to fabricate your own to do the job. I bent up two L-brackets out of thin alloy and bolted them to the side-panel with two 3mm screws. With hindsight, I could have used only one. Another way would be just to glue the new bracket to the back of the sidepanel. Thick plastic card would do the job too.
To be honest I was looking for anything didn't really mind about that bit, although I've got a feeling that contributed to it being lost. However I'll keep that in mind if I do happen to find a panel for it. At the moment it's literally anything that will fit to just cover the exposed wires.
5Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sat Jun 06, 2015 5:05 pm
Comberjohn
Comberjohn
The early ones are getting harder to find now but keep an eye on eBay. They do turn up fairly regularly.
Remember, its NOT the ones with the rod at the rear of the panel. That's the later one.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
6Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sat Jun 06, 2015 5:08 pm
Ebay.  ......as you live in UK you could also try Motorworks or James Sherlock
who have used parts.
Motobins have a new one in primer for £ 54,-.
7Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sat Jun 06, 2015 5:32 pm
TheJoker
TheJoker
@Inge K. wrote:Ebay.  ......as you live in UK you could also try Motorworks or James Sherlock
Guess my googling skills are not as good as I thought Embarassed , will order the motobins one right now. Keep forgetting about the specific BMW websites, having owned Japanese bikes before; normally first and last call was ebay or wemoto.
8Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sun Jun 07, 2015 1:02 pm
Shep
Shep
Replacement side panel Z
The grey panel is the 1984-1985 model with two bungs and a bottom bracket that the steel spindle on the frame slides through.
The black panel is from a 1986 production bike with one bung, one hook (at bottom) and a spindle that slides into the rear fairing tail section.
Shep
9Back to top Go down   Replacement side panel Empty Re: Replacement side panel Sun Jun 07, 2015 10:32 pm
Good photos Shep.
10Back to top Go down   Replacement side panel Empty Re: Replacement side panel Mon Jun 08, 2015 5:10 pm
When fitting/removing the early sidepanels, get your hand behind the panel to push the bracket with the rubber grommet along the frame peg.
Just pulling the sidepanel will break the bracket.
11Back to top Go down   Replacement side panel Empty Re: Replacement side panel Mon Jun 08, 2015 8:58 pm
TheJoker
TheJoker
@sidecar paul wrote:When fitting/removing the early sidepanels, get your hand behind the panel to push the bracket with the rubber grommet along the frame peg.
Believe mine may be broke already the left hand side (that's remaining) kinda rocks when it's on the bike. Just held on by two bungs.
