Gauge removal... for dummy on Sun Oct 25, 2015 12:16 pm
gringoloco
My gauges stopped working, so I installed a digital speedo with the sensor, which is cable tied onto the side of my handlebars. Now I want to remove everything and connect whatever I can to the digital one (it's a Koso DB-01R).
The problem is that my electronics abilities are limited to testing for power to the wires and soldering them sloppily together. That's it, although I'm willing to learn.
Since I'm making a cafe racer I want the absolute minimum legally required by Austrian authorities. So, I don't need hazard lights, heated grips, temp gauge, RPM indicator..... what else could I eliminate? Fuel gauge would be nice though, but how hard is that to wire into the Koso if I was to remove the big one?
And for the things I do need to pass inspection (high beam, turn signal, neutral... anything else?) what's the easiest way of wiring them?
I read that the alternator doesn't work if I remove the original gauges, is this true? What's the simplest way around that?
I know, it's all over my head, but I don't mind failure.... it's the only way I'll learn anything.
