1Back to top Go down   Hazard Lights | how to connect Empty Hazard Lights | how to connect Sun Nov 29, 2015 4:03 am
Chocolate
Chocolate
Hello!
On my bike I don't have a Hazard Lights and I would like to connect one.
I found one on eBay, see picture.
How and especially where do I connect, is there a allredy a plug?
The pictures from under the tank are not from me, maybe there is a plug that is meant to use for the warning flashing light.
Cheers espresso
Hazard Lights | how to connect <a href=Hazard Lights | how to connect Image13" />
Hazard Lights | how to connect <a href=Hazard Lights | how to connect Image14" />
Hazard Lights | how to connect DqkE4
Hazard Lights | how to connect Fi_har11
Thanks for your advise
2Back to top Go down   Hazard Lights | how to connect Empty Re: Hazard Lights | how to connect Sun Nov 29, 2015 4:08 am
Correct expression is Hazard Lights or Hazard Flashers. Mine already had them installed and working, so I haven't looked at wiring.
The experts here will give good advice as usual, I'm sure.
3Back to top Go down   Hazard Lights | how to connect Empty Re: Hazard Lights | how to connect Sun Nov 29, 2015 4:31 am
Chocolate
Chocolate
# thanks Bill, corrected that :-)
4Back to top Go down   Hazard Lights | how to connect Empty Re: Hazard Lights | how to connect Sun Nov 29, 2015 5:33 am
The switch connects into the harness under the tank on the left. See diagram below which is from the trouble shooting page linked off the Portal tab.
See connector #12
The wire colours are...
Brown
Yellow/Violet
Blue/White
Hazard Lights | how to connect Under-tank-wiring
 Hazard Lights | how to connect Austra12    Fuel:  95 Octane
5Back to top Go down   Hazard Lights | how to connect Empty Re: Hazard Lights | how to connect Sun Nov 29, 2015 5:53 am
Chocolate
Chocolate
# thanks Kaptain, so there must be a unused plug (number 12) and I just have to plug my cable and that's it right?
6Back to top Go down   Hazard Lights | how to connect Empty Re: Hazard Lights | how to connect Sun Nov 29, 2015 7:59 am
Pretty much that's it (unless there's some K75 anomaly but I doubt it).
There may already be a connector plugged in from a previous switch that may have been surgically removed 🤡 ... Just swap it for the one you have. The hazard function is controlled by the flasher controller which is the one bottom left in the electrical box in your photo.
7Back to top Go down   Hazard Lights | how to connect Empty Re: Hazard Lights | how to connect Sun Nov 29, 2015 8:57 am
Chocolate
Chocolate
# Kaptain, perfect, I understand.
When I'm ready and it works, I'll post it!
