1Back to top Go down   K100RT and parts Aust Empty K100RT and parts Aust on Sat Nov 21, 2015 9:32 pm
Rockman
Since I'm changing from the K100Rt to a K1200Rs, my spares collection is up for sale/relocation. Basically I want a little money for the new bits. For the SH stuff make me an offer. Some bits free for the cost of postage.
New stuff
fuel pump Bosch 0680464998                     $50
inlet rubbers for manifold x4 K2v 60755-k      $20
rear toolbox lid 52.53 1455219 later K100      $10
wheel bearing x 1 and seal, spacer               $10
output shaft bearing post 86?+k1100            $40
seal bmw 1-461 185                                    $5
used stuff
set coils (4)
front blinker lenses RT x2 with bulb holders
lh switch block
instruments - 1 complete but crazed faces, 1 in bits. still a housing left and the aluminium base
relays etc 1459224 x2, 895092 x1, 61.13-1459003 x1. not sure what these are exactly.
rear blinkers rhs, 2x rear foot pegs, misc bits
fuel computer 1986, marked ok
tail light lens
rear wheel cover
starter motor needs new brushes ex my K100
throttle grip gears ok, rear wheel bolts, bar end weights, misc bits in bag
fuel pump used, condition unknown
fuel pump mount rubber looks ok
sidestand with spring, pivot bolt
injectors x 4 used, need cleaning but were running ok when I took them out.
sump plate with oil filter cover. one screw broken off
ignition switch in rubber housing, with key
rear blinker lenses x2, rear wheel cover, headlight bulb cover, misc bits in a bag
gear lever
radiator guard mesh only
fuel cap and mount. no key
knee pads x2
headlight, complete + stoneguard
gearbox history unknown, bought as a spare. I took the cover off and everything inside looked ok so I resealed it.
gearbox 2nd or 3rd gear gone. might suit spares
fork springs x2
final drive with good disk, splines worn suit spares 20t I think
tail shaft 16t, splines worn but useable
rhs side cover early K, black
rear master cylinder. will need kit
rear wheel
swingarm
seat
poor cond but could be repaired if you are keen
2Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sat Nov 21, 2015 10:54 pm
dee why
dee why
Hi Rockman,
I would be interested in the new fuel pump and I'm still after a functioning clock if there is one in your second hand instruments collection.
Cheers,
D
Dee Why
04/86 K100 VIN 0009479 Columbia Silver
3Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 22, 2015 1:11 am
Rockman
@dee why wrote:Hi Rockman,
Cheers,
D
G'day D
both instruments have clocks but I dont know if they work. Do you know how to check them? If you like I'll send you the bitsa with the pump for free and you can take a punt from there. I'll get a price on postage and let you know.
cheers, Phil
4Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 22, 2015 2:43 am
dee why
dee why
Thanks Phil.
Sending PM.
Dee Why
5Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 22, 2015 6:25 am
gmaizey
gmaizey
Hi Rockman
I'd be interested in the new rear toolbox lid, and the secondhand throttle grip etc (though don't really need the rear wheel bolts), and the knee pads....assuming they would fit my motorcycle...I'm down Brisbane way.
Cheers Graeme (1991 K100RS)
6Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 22, 2015 7:55 am
beanoldboy
beanoldboy
may I have those inlet manifold rubbers please
N
http://www.airware.com.au
7Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 22, 2015 10:50 pm
I'll take the following...
Fuel pump
Fuel pump mount
Fuel cap
Seat > providing the base is in OK condition
pm on its way
EDIT: I'll also take the relays and the injectors if you don't want too much for them
  K100RT and parts Aust Austra12    Fuel:  95 Octane
8Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 22, 2015 11:48 pm
Rockman
Kaptain Holister wrote:I'll take the following...
Fuel pump
Fuel pump mount
Fuel cap
pm on its way
The new fuel pump is gone, but there is a used one there. Dont know if it works. Buy me a beer sometime if it does.
OK on the rest. I'll wait for your pm
Phil
9Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Mon Nov 23, 2015 3:50 am
hi phil ...
interested in the gear shift lever
and the fuel computer
will send pm as a reminder
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OK100RT and parts Aust Au-log10
10Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Mon Nov 23, 2015 4:54 am
@charlie99 wrote:hi phil ...
I hope the gear shift lever is still with the gear box, as I bought the gear boxes.
11Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Mon Nov 23, 2015 6:26 am
good luck mate
hope they workout for you
12Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Mon Nov 23, 2015 6:40 am
@charlie99 wrote:good luck mate
Hey Charlie, if the gearboxes have levers on them your welcome to one.
13Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Mon Nov 23, 2015 5:44 pm
Rockman
Its an extra one. I'm "almost" sure the boxes have levers.
CORRECTION. Neither greabox has a lever. Up to you to decide who gets it.
14Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Thu Nov 26, 2015 12:25 am
Rockman
All parts posted today.
15Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 29, 2015 9:35 pm
Mine arrived, thanks Phil
1988 K100 RS
1999 K1200 RS
1987 K100RS DJP sidecar
16Back to top Go down   K100RT and parts Aust Empty Re: K100RT and parts Aust on Sun Nov 29, 2015 10:11 pm
beanoldboy
beanoldboy
arrived this morning , thank you very much.
