1Back to top Go down   how much fork oil to use Empty how much fork oil to use Tue Dec 01, 2015 4:36 am
piseth
piseth
Hi guys, i don not know if this post is in the correct section. Just wanna check, how much oil should we put in the front fork? Thanks in Advance
2Back to top Go down   how much fork oil to use Empty Re: how much fork oil to use Tue Dec 01, 2015 5:22 am
Chocolate
Chocolate
Hello to Cambodia!
Which K are you driving?
I just changed the oil in my fork, it's a K 75 from 1992 with the new Showa Fork, my other K is 1991/5 and has the old brembo Fork. The fork was change to the new Showa 1991/8 and other parts.
The amount is different and depends on just changing or if you took the fork apart and cleaned it. Be carful witch the fork screws, where the oil comes out they ONLY have 8Nm old fork and 6Nm new fork!
Give us some more info please :-)
Hoopla I just saw you have a K 100 from 1990, a 2V?
330ml each fork.
A list, hope it helps:
https://www.k100-forum.com/viewimage.forum?u=http%3A%2F%2Fi56.servimg.com%2Fu%2Ff56%2F17%2F70%2F28%2F81%2Ffork_o10.png
3Back to top Go down   how much fork oil to use Empty Re: how much fork oil to use Tue Dec 01, 2015 1:40 pm
piseth
piseth
Hi Espresso , no idea what i have. Seller says its 16v. My comes with the brembo brakes
Laughing Laughing Laughing
K100 RS 1990 December
Last Location: Japan
Current Location: Cambodia
vin:0201460
4Back to top Go down   how much fork oil to use Empty Re: how much fork oil to use Tue Dec 01, 2015 3:59 pm
If it's produced late -90 like your signature says, it's a 16V.
And you have a Marzocchi fork.
5Back to top Go down   how much fork oil to use Empty Re: how much fork oil to use Tue Dec 01, 2015 5:52 pm
Chocolate
Chocolate
# Thanks Inge :-) you are rigth!
And if I read the list correct and if you only change, NO dissembling,
it should be 380ml in each fork.
6Back to top Go down   how much fork oil to use Empty Re: how much fork oil to use Tue Dec 01, 2015 8:28 pm
piseth
piseth
thanks Espresso
vin:0201460
