1Back to top Go down   Fork length BMW K75S Empty Fork length BMW K75S Tue Apr 19, 2016 4:22 pm
zach_ross
zach_ross
Hello,
Was wondering if anyone knew the total fork length on a BMW K75S, as I can not access my bike right now it would be great if you could help me out.
Thanks!
Silver 1987 K75S
2Back to top Go down   Fork length BMW K75S Empty Re: Fork length BMW K75S Wed Apr 20, 2016 2:38 am
Hi Zach, my 1990 naked K75 had the factory "S" forks option on it which I believe are the same as those fitted to the K75S.
The top of the fork tubes are level with the top of the upper triple clamp so with the bike jacked up so the front wheel is clear of the ground I measured from the top of the top triple clamp to the axle bolt. It is approximately 813 mm (see photos). Hope this is some help.
I've also included a photo of the "S" mark on top of the fork cap which should be the same as yours.
Fork length BMW K75S Image18
Fork length BMW K75S Image20
Fork length BMW K75S S_fork11
3Back to top Go down   Fork length BMW K75S Empty Re: Fork length BMW K75S Wed Apr 20, 2016 11:55 am
zach_ross
zach_ross
Gaz80 wrote:Hi Zach, my 1990 naked K75 had the factory "S" forks option on it which I believe are the same as those fitted to the K75S.
This is exactly what I needed, thanks so much for the help.
Silver 1987 K75S
