1Back to top Go down   Older K's Empty Older K's Tue Feb 23, 2016 4:16 am
Frank47_1999
Frank47_1999
This might not apply to K models but since some are now close to 35 years old perhaps it should kept in mind.
Last year the tachometer needle on my R90S started to make a clicking noise and rapidly flicker from idle to around 3000 revs. I removed the instrument cluster and took it to a specialist where a small gear was replaced and as a precaution replace the cable. I also took this opportunity to recalibrate the speedometer. (Police tend to spoil the ride) (I got the K speedo calibrated last month)
The rapid flickering re-appeared yesterday. Strange I thought, the new gear and cable shouldn’t have worn out that quickly. I took it back and the man confirmed my thought. Tests showed everything was running perfect UNTIL he touched the OUTER cable. It turned out that the now 40 year old outer cable has become so old and inflexible that it was ‘interfering’ with the inner cable operation.
He’s making a new cable, re-assemble and test out it on his work bench. I’ll pick it up tomorrow. Cost $40
Frank
2Back to top Go down   Older K's Empty Re: Older K's Tue Feb 23, 2016 4:52 am
hi Frank
many times I have seen similar
but have you seen a cable injector adaptor ?
the mechanics are that a thumbscrew shrinks a rubberised gland  that mates to the outside of the cable  on one end of the adaptor ...the other end mates to the working part of the inner cable
an airesol   can of spray can then  presurise fluid through the core of the cable ....
 have used many things in the past...like wd 40 etc with some very positive results.. blakey loves lanotech
good luck
3Back to top Go down   Older K's Empty Re: Older K's Tue Feb 23, 2016 5:09 am
Frank47_1999
Frank47_1999
Charlie
have you seen a cable injector adaptor ?----------------------Never even thought about it.
Last night not being the cable or the tacho gears I feared that it was the cam drive gear that was the problem so when he told me what the problem was I was so relieved.
