1Back to top Go down   Fan rebuild | Laser cutting service Empty Fan rebuild | Laser cutting service on Tue Feb 23, 2016 4:23 am
Chocolate
Chocolate
If anybody is interested in getting a new fan, here is a way how to mount.
The plan and pictures are from a other forum.
You will need a laser cutting service, if you make 10 pieces, it will not be more than 5€ a piece, or less.
You will find the SPAL fan on eBay or somewhere else.
Fan rebuild | Laser cutting service <a href=Fan rebuild | Laser cutting service Image20" />
DXF File
PDF File
Fan rebuild | Laser cutting service 17_Luefterhalter
Fan rebuild | Laser cutting service <a href=Fan rebuild | Laser cutting service Image14" />
Fan rebuild | Laser cutting service <a href=Fan rebuild | Laser cutting service Image16" />
Fan rebuild | Laser cutting service <a href=Fan rebuild | Laser cutting service Image17" />
Fan rebuild | Laser cutting service <a href=Fan rebuild | Laser cutting service Image18" />
Fan rebuild | Laser cutting service <a href=Fan rebuild | Laser cutting service Image19" />
2Back to top Go down   Fan rebuild | Laser cutting service Empty Re: Fan rebuild | Laser cutting service on Tue Feb 23, 2016 12:30 pm
Who needs a template or laser cut? All you need is two scraps of aluminum.
Fan rebuild | Laser cutting service Spalfa2
3Back to top Go down   Fan rebuild | Laser cutting service Empty Re: Fan rebuild | Laser cutting service on Tue Feb 23, 2016 2:50 pm
Chocolate
Chocolate
Yeah, seams to work, leasy going, looks interesting Duck :-)
I prefer spending 4€ for a laser cut stainless steal,
good old over engineering!
It will last longer then the rest of the bike and looks better.
The difference between US and German production :-)
The other 9 are birthday presents for free.
I even did this
Fan rebuild | Laser cutting service Senker
4Back to top Go down   Fan rebuild | Laser cutting service Empty Re: Fan rebuild | Laser cutting service on Tue Feb 23, 2016 11:12 pm
Following the instructions on another forum I just took the OEM fan out of the bracket, cut the bracket in half on the horizontal, and pop riveted it to the Spal frame.  About 5 minutes with a round file had the top hole reshaped to line up with the hole in the radiator and I reinstalled everything.  Total time to hack the frame and put the Spal in it was about a half hour, and another 10 minutes to solder the electrical connections.
