1Back to top Go down   K75 headlight no workee - help! Empty K75 headlight no workee - help! Mon Mar 07, 2016 4:18 pm
playlikewedream
playlikewedream
Hi guys
You will remember the €1 k75,
well it has a few issues and my mate is going through them one by one.
The latest one is the headlight won't light up, the parking light is OK and the extra light fitted to the fairing above the headlight is working and the headlight flasher is working ,so changed the bulb and issue is still the same. Any ideas gratefully received.
Pat
K75 headlight no workee - help! Ir-log10K75 headlight no workee - help! Ir-log10
;BMW; K1 1990 Laguna Blue and Yellow ;BMW;
;BMW; K1100RS 1997 Sedien Blue.;BMW;
Its not about the journey or the destination, it's about the friends you make on the way.
2Back to top Go down   K75 headlight no workee - help! Empty Re: K75 headlight no workee - help! Mon Mar 07, 2016 5:20 pm
G'day Pat.
I've split this topic as the information about your friend's no-headlight condition will get lost under the original "Which battery" topic.
Last edited by blaKey on Mon Mar 07, 2016 9:46 pm; edited 1 time in total (Reason for editing : Not paying attention!)
3Back to top Go down   K75 headlight no workee - help! Empty Re: K75 headlight no workee - help! Mon Mar 07, 2016 5:34 pm
I'd start by checking for power starting at the bulb and working your way back to the handlebar switch.
You may find the headlight's on/off switch may need a good clean.
Use the search function to see previous post's fixing and cleaning of the switch.
Let us know how you go.
4Back to top Go down   K75 headlight no workee - help! Empty headlight not working Mon Mar 07, 2016 5:36 pm
playlikewedream
playlikewedream
Hi Blakey
The bike starts, it's the headlight not working
Pat
PS your post arrived after I posted this.
5Back to top Go down   K75 headlight no workee - help! Empty Re: K75 headlight no workee - help! Mon Mar 07, 2016 5:42 pm
Fixed...sorry Pat!
6Back to top Go down   K75 headlight no workee - help! Empty Re: K75 headlight no workee - help! Mon Mar 07, 2016 5:47 pm
I'm with Blakey. My bet is also the high/low switch - the high beam contact is either covered in a thin film of melted plastic or heat produced by the current has caused it to recess in the plastic holder. Seen both problems.
7Back to top Go down   K75 headlight no workee - help! Empty headlight not working Mon Mar 07, 2016 5:51 pm
playlikewedream
playlikewedream
Hi Dai
Will let you know how he gets on.
Pat
8Back to top Go down   K75 headlight no workee - help! Empty Re: K75 headlight no workee - help! Tue Mar 08, 2016 10:54 pm
How many miles/km?
Usual suspect is the headlight switch as mentioned above.
Though a replacement left combo switch is the usual solution, there is a workaround with a relay that can be done to fix this. (long story but I had a HL switch go bad and needed to come up with a quick solution)
9Back to top Go down   K75 headlight no workee - help! Empty Re: K75 headlight no workee - help! Thu Mar 10, 2016 3:51 am
I wonder if the headlight bulb housing connector is burnt on the low beam, was the H4 that you removed a high wattage unit or a stock unit, flasher means high beam works but so far I only get that low main beam is a dud?
10Back to top Go down   K75 headlight no workee - help! Empty Re: K75 headlight no workee - help! Thu Mar 10, 2016 3:58 am
good point keith
worth looking at closely
