Serious electric problem? Fri May 14, 2010 4:47 am
Vudis
So, this year, after surviving a chill winter (for 2 months the outside temp never reached more that -21C), my bike shows some strange signs of what we may call a serious electrical problem.
The higher rpm's are, the more brightly battery lamp goes on. If I try to stop my bike, when I press stop, the lamp illuminates quite strongly, but not fully. When I turn on other things that use electrical power (signal or smth), the lamp could be seen illuminating very very slightly, when I press stop, the lamp shines quite clearly, but fells it shines about 50 percent less, than at full.
Here's the light:
In this picture it illuminates fully. When the engine works at 1000 rpm, it illuminates very very slightly. You can hardly see it. The higher rpm is, the more strongly it illumintes, but when I press to stop the bike, and the rear brake lights turn on, the battery lamp illuminates quite clearly, but as I said not fully.
Gosh, am I forgetting my English?
Guess you understood.
J.
Here's the light:
J.
