Chocolate
Chocolate
Hello!
Just preparing a tool packet for a tour.
Just a short question:
What size of hex key, Allen key are needed?
I don't want to take to much or to little ;-)
K75, hex key, Allen key | size needed? Inbus-sruby
K75, hex key, Allen key | size needed? 6156250
werewasi
werewasi
went on a trip recently and before leaving just went around the bike and ascertained sizes e.g front wheel release allen bolts.
I have a set of hex allens but they all fit the ONE socket (1/2 drive) so you don't end up having to cart all those sockets that you have showing in that case. I don't even take the ratchet or bar because there is always someone on the road who has 1/2 drive stuff.
You can get a set of hex s which come both as long and short with the one socket for $24 on E Bay. and they mightn't be GEDORE quality but they're strong enough to use when dismantling a K to do clutch.
K100RS  1983 and 1986 (bought a 2nd and put them both together in a dark garage thinking that i would get a heap of parts from the progeny but nothing happened- think they're gay)  Laughing Laughing Laughing
1985 K75, Guzzi V7 Special, 1986 GB500, 1974 T500, 1986 MB5 with the whoppa 100cc engine transplant, NC 700 SA Honda, two 1986 Kawasaki BR250s
Chocolate
Chocolate
Thanks werewasi!
1/2 ratchet will be fine.
I will get a set from a friend, I would just like to tell him the sizes I need. Without missing anything.
Brakes bolts
Gear oil bolts
Etc.
A list of standard alen bold size for the K would be practical.
3, 4, 5, 6, 8 & 10mm
Bikes 2004 K1200GT 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
@RicK G wrote:3, 4, 5, 6, 8 & 10mm
agree rick
would like to add the most common high torque  to release allen keys bolts use the  5, 6, 8  allen head ...generally
the 3 , 4  lower sizes usually are workable with a good allen key set whilst on the road
don't forget to have a socket for the rear wheel bolts 17mm
 take some common bolt sizes 6mm x 20 . 6mm x 25  and some nuts to suit ...so far I have used 5x 6mm bolts and nuts to fix loose things on other riders bikes ...about 5 or 6 fuses of different current ratings  and a couple of stop and tail globes
take your own ratchet and extension to suit ...else you are dependant on someone else for any repair ... else plan for a further 3 hours on the side of the road and lots of hope that someone will stop ...with a proper kit
there is an old urban myth  ...if you take it with you,  the likelyhood that you will need it diminishes greatly ...
there are a few threads in the forum about what we carry as tool kits  .........see here
https://www.k100-forum.com/t564-what-do-you-carry-in-your-tool-kit
good luck
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OK75, hex key, Allen key | size needed? Au-log10
The factory tool kit is all you really need.
For a long tour an oil filter wrench is handy.
And a compact multimeter and some electrical goodies.
Davep
Davep
@duck wrote:The factory tool kit is all you really need.
I must admit I've never had a bike come with a tool kit so always put something together myself, but are you saying the K tool kit is the one to have??? Shocked Shocked Shocked Very Happy  Happy days!!
There are a few small exceptions (some peg plate bolts and the 12mm rear pivot on paralevers) but you can just about disassemble and put back together an entire K bike with the factory tool kit. Obviously you'd want a torque wrench to assemble one but for road repairs you can do pretty much anything with the supplied toolkit.
Davep
Davep
You have no idea how much you have saved me!
Not only in money but also in space!! I'm quite new to the K world and am planning a few long range trips in the next year. Space becomes a bit of a luxury when you're on the road for a week or two! anything that saves me 1/2 inch of space is a god send!  I will have to get a picture of the 1979 Suzuki tool kit that I use to carry... how you'll all laugh..
Here are the contents of the tool kits (ignore the "car" terminology)
K tool kit contents
I think the full BMW tool kit is a must. I also supplement that with a small range of ⅜ and ¼ Allen head and hex head sockets with ratchets and a small extension. I think ½ drives are too big and take up too much room plus sometimes they're a little wide to use on some screws/bolts in confined spots.
I also carry some good screwdrivers, long nose pliers, small DMM, knife etc.
Everything is packed loose so it fits in with less space.
Spares.... Clutch and throttle cables, an assortment of bulbs, fuses, tyre valves and caps and spare SPs are a must but on longer treks I'll also take relays, starter relay, temp controller. On my recent trip across the Nullarbor, due to the remoteness, I threw in a starter motor kit and voltage regulator just in case.
Duct tape, electrical connectors, wire, cable ties, very basic first aid supplies.
One thing I will not leave without is a puncture repair kit. I've used the Co² canisters to inflate but after my last puncture I think I'll get a small compressor for longer trips. If I'd had a puncture out on the Nullabor it could have been hundreds of kms to an air compressor as some of the roadhouses out there don't provide air. Co² canisters will only get you up to around 25psi
  K75, hex key, Allen key | size needed? Austra12    Fuel:  95 Octane
Chocolate
Chocolate
Thanks all!
Now I've got enough info.
The links are great.
I have a very smal tent and sleeping bag (British army Smile
The whole package will be less then 5kg for 3weeks.
I even cut the toothbrush in half :-)
K75, hex key, Allen key | size needed? Frontpicture_SolarisDS_web
K75, hex key, Allen key | size needed? MavNTeyGK_qWwHVJBdwzklg
K75, hex key, Allen key | size needed? Northern-lights-front
Just take along some zip ties, duct tape and a hammer. Very Happy
@blaKey wrote:Just take along some zip ties, duct tape and a hammer. Very Happy
And WD-40.
And it's important that it is white zip ties, only.........just ask Blakey.
A McDonald steam hammer can come in very handy.
