MikeisonTV
MikeisonTV
Bottom 7.5 fuse keeps blowing and now fuel pump isn't working. Are these too the same problem? As in, does the fuel pump need that fuse to power (spin)?
What can I do to figure out why that fuse keeps popping?
Thanks gents.
Bottom 7.5 fuse keeps blowing and now fuel pump isn't working. B1B2DDEA-5F8B-4F81-BA1B-89733D53E850
The #7 fuse feeds the horn relay and the flasher unit. It should have no bearing as to the fuel pump working or not.
Check the 4 pin plug that goes to the tank they are noted for problems, you may need to squeeze the female pins so they make good contact or just cleaning it may work. I have replaced two of those over the years with 4 pin 6mm automotive type connectors and have had no more trouble.
As for the fuse blowing you will need a good circuit diagram to chase the problem down. If you need one PM me and I will give you a link.
MikeisonTV
MikeisonTV
I'll try the 4 pin under the tank in the morning and see if the pump will spin. She just slowly choked out and died. Gas was pretty low so I hoped that was the culprit turns out to be more. Please do send the diagram link for the fuse when you get a second. Thank you so much Rick.
PM sent
kennybob
kennybob
The fuel pump runs on fuse #6, which it appears you are missing.
MikeisonTV wrote:Bottom 7.5 fuse keeps blowing and now fuel pump isn't working. Are these too the same problem? As in, does the fuel pump need that fuse to power (spin)?
I think Mike is referring to the "bottom 7.5amp fuse" which is #6 (the missing one).
If this is the case then the fuel pump windings or fuel level sender may be shorted. Fuse #6 also goes to the temperature controller. Try pulling the temp controller first and see if the fuse blows. Then disconnect the pump or visa versa. It's likely going to be the pump. When did you last change the fuel filter?
 Bottom 7.5 fuse keeps blowing and now fuel pump isn't working. Austra12    Fuel:  95 Octane
To test the fuel pump you can jump 12V directly to it. The smaller diameter terminal on the pump is 12V+.
Probably a good idea to make a point of not creating sparks in the fuel tank when doing this. i.e. Connect leads to the fuel pump first, then your power supply outside of the tank.
kennybob
kennybob
delete
Mike. Does the fuse blow....
  1. As soon as you put it in
  2. When the ignition key is turned on
  3. When you press the starter
EDIT: due to kennybob's post being completely altered, I've deleted my response because it was not relevant.
kennybob wrote:The radiator fan is likely locked up and the stall current is blowing fuse #6.
The fan motor is protected by fuse #7, beside the fuel pump fuse #6 protects the PCB inside the temp management relay.
MikeisonTV
MikeisonTV
I meant to update sooner. RICK nails it again...tighten up the 4 pin connector under the tank...she fired right up. Cool
kennybob wrote:Just to quickly test if the pump is working and to avoid sparks in the tank, with the key off, you could put a jumper wire from the right-hand side of fuse 4 to the left side of fuse 6 to put power to the fuel pump.
This is a test, it is only a test.  Do not try to operate in such a manner.
The proper way to test the pump is to isolate it first, away from the circuit that's causing the short. In any case the fuse would blow straight way again so you'd be none the wiser. Don't even think about trying that without a fuse.
MikeisonTV wrote:I meant to update sooner. RICK nails it again...tighten up the 4 pin connector under the tank...she fired right up. Cool
most often its the simple solution. Onya rick.
So whats causing the fuse to blow?
MikeisonTV
MikeisonTV
The fuse seems to be ok now
I reconfigured my DIY mustang fuel pump design by:
1: gutting a dead BMW fuel pump for the metal housing
2: I bought a Carquest E2024 fuel pump from eBay seller Herko and Genuine Walbro Fuel Pump Sleeve 122-3074 submersible foam noise suppressor sleeve on eBay
3: the pump fits super snug in the sleeve, the sleeve then super snug in the gutted BMW pump housing. Since the black rubber on the pump mount has been falling apart over the years...I cut the "distended rubber off at the bottom. I added a screw tightening o clamp to the top for added security.
My guess is the first shitty design I had was maybe shorting the fuse as one of the wires might have touched the other when it fell through the orginal mount...but I'm more of a designing brain and a wrench than an electrician...
Finally bought a TRUE RMS multimeter so I can stop shying away from electrical gremlins like you pros
MikeisonTV
MikeisonTV
duck wrote:To test the fuel pump you can jump 12V directly to it. The smaller diameter terminal on the pump is 12V+.
That's exactly how I did it. I clean the pumps using the same DIY method used for cleaning the fuel injectors.
Using a battery, carb cleaner, and a tire valve stem like this:
(no need to melt if you drill the hole in the tire valve stem one size narrower  than the red straw)
