1Back to top Go down   Acewell RPM indication Empty Acewell RPM indication Tue Sep 13, 2016 7:20 pm
Oliveri
Oliveri
Ok, so i recently installed an Acewell-2853 and used the Blue/Black [16] wire coming from the coil. However, it's 'jumping' up and down the rev-range. I've heard that using a resistor 'cleans up' the signal and eliminates this. After doing some research, I've come across this:
1.)
                                         Brown  [Ground]
     Ace-2853 (Yellow)          100K ohm 0.5 W resistor
                    10 nF 630V capacitor
                        Coil
                        Blue/Black [16]
 2.)
                              Ace-2853 (Yellow)
10K ohm 0.5 W resistor [15K or 20k if higher resistance is required]
                                Coil
                                Blue/Black [16]
Any experience with either of these suggestions?  Which would be the preferred solution?
"Keep the paint up, and the rubber down
1988 K100RT...#0096960 ..."Heisenberg"...Status: Work in progress
http://www.oliveris.com.au
2Back to top Go down   Acewell RPM indication Empty Re: Acewell RPM indication Wed Sep 14, 2016 12:04 am
KJustin
KJustin
I had the exact same problem with the same Acewell. Take a look at this thread from the motobrick forum. http://www.motobrick.com/index.php?topic=6814.0
I tried both the solution in reply 2 and reply 4. The former helped, but didn't totally solve the problem. The second totally solved the problem.
1985 K100 Cafe Racer (formerly an RT), VIN 0051736
3Back to top Go down   Acewell RPM indication Empty Re: Acewell RPM indication Wed Sep 14, 2016 12:31 am
can I add that the guys in that post used a general purpose type diode that are not known to conduct well at higher frequencies
the old silicon diode in914  in4148 etc is rated up to hundreds of thousands of hertz
what were looking for here is something that switches on fast ....and ...switches off fast
perhaps any schotky (very fast )  diode (rated for higher voltages than 100 v) will do a far better job ...
just to add to the conundrum
4Back to top Go down   Acewell RPM indication Empty Re: Acewell RPM indication Wed Sep 14, 2016 5:19 am
I'm in agreement with Charlie. When it comes to fast switching, use a schottky diode. In this case it's not so much the total frequency that a diode is capable of switching, but as Charlie says, how fast it can switch on and off.
5Back to top Go down   Acewell RPM indication Empty Re: Acewell RPM indication Wed Sep 14, 2016 11:26 am
Oliveri
Oliveri
Great, now I'm almost more confused that before. Ok, so has anyone with an Acewell used any of my first mentioned options? Has it worked?
If not is there anyone that can explain ( inc. diagram for a 10 year old) how to fix it for certain. Yes, again pretend I'm 10.
Sorry, my electronic understanding is a bit like Acewell RPM indication 652573Acewell RPM indication 178468 Acewell RPM indication 87464 but I'm learning.
6Back to top Go down   Acewell RPM indication Empty Re: Acewell RPM indication Thu Sep 15, 2016 6:23 am
On the diagram in post 4 that shows a 1n4007 diode, replace that diode with a 1n5819. Your local electronics shop will sell you the right component. I don't have an Acewell speedo but it should fix the problem permanently.
7Back to top Go down   Acewell RPM indication Empty Re: Acewell RPM indication Thu Sep 15, 2016 7:17 am
Oliveri
Oliveri
Thanks again everyone for your time & knowlage. Acewell RPM indication 723598 Will do exactly that ...
Question: the 33k and 10k resistors how many watts? Same for the cap, how many V's? Or did I miss that somewhere?
8Back to top Go down   Acewell RPM indication Empty Re: Acewell RPM indication Thu Sep 15, 2016 11:40 am
Brad-Man
Brad-Man
Looks like post #2 had .5 watt for the resistor...
Acewell RPM indication Usa-lo10
