Number of posts : 7867
Sounds like you are just going to fit right in.
We are now taking bets on how long it takes you to get a second K!. Seems to me you got a good dose of Kpox that just hasn't manifested itself yet.
Duck is nicely set up with K75 turbo and there are a few out there. Very impressive too. K engines have great torque and have proven themselves pretty much bulletproof. 100k miles is nothing to them. Just keep eye on the valve clearances. Other stuff like timing chains etc are a cinch to get at.
If you are running turbo and find yourself running hot Motorbike Mike races a K100 and has a very instructive series of posts on a water/oil pump upgrade using standard BMW parts off later Ks. Its entirely possible yours might give up ghost in time as its a common side effect on bikes that have sat unused for years. Its easy to get at but requires care in doing it.
This also happens seals that harden over time due to non use. I changed footpeg rubbers a few months back and was amazed at the difference even that made.
Somehow you should make your way over here, we have some nice K roads!
1971 Yamaha 125 YAS-1
