1Back to top Go down   '87 K100rs left me stranded. Empty '87 K100rs left me stranded. Sat Aug 27, 2016 1:30 pm
kauaiwoodcock
kauaiwoodcock
My bike was running great, out for a nice ride, pulled over to check my map. Then when I tried to start it, it cranks over but no go. Fuel is dripping from the headers. Once I got it back home I find, good spark and plenty compression, but fuel runs out as soon as it's cranked over. I don't have time to get into it as I'm off to ride dirt in Nevada but thought that I'd put it out there to see if anyone has seen this before.
2Back to top Go down   '87 K100rs left me stranded. Empty Re: '87 K100rs left me stranded. Sat Aug 27, 2016 11:00 pm
Brad-Man
Brad-Man
Injectors stuck open?
'87 K100rs left me stranded. Usa-lo10
3Back to top Go down   '87 K100rs left me stranded. Empty '87 K100RS left me stranded Sat Aug 27, 2016 11:15 pm
Hi there, maybe a faulty fuel pressure regulator?? Cheers Tom
4Back to top Go down   '87 K100rs left me stranded. Empty Re: '87 K100rs left me stranded. Sat Aug 27, 2016 11:42 pm
Pull the plugs and find out if it is 1 or more cylinders flooding
5Back to top Go down   '87 K100rs left me stranded. Empty Re: '87 K100rs left me stranded. Sat Aug 27, 2016 11:56 pm
I'd say the coolant temp sensor has gone open circuit. Pull the plug on your FICU (under the seat) and measure the resistance between pin 10 and 13 counting from the lead end. Should be around 2,500 ohms on a cold engine (20oC) but I'm guessing you won't get a reading just a '1' on your DMM.
 '87 K100rs left me stranded. Austra12    Fuel:  95 Octane
6Back to top Go down   '87 K100rs left me stranded. Empty Re: '87 K100rs left me stranded. Tue Aug 30, 2016 12:05 pm
kauaiwoodcock
kauaiwoodcock
Hey, thanks you guys. I'm off to Nevada to ride dirt on my ATK  Sounds like I'll have to get into it when I get back.  I am not looking forward to it, but it's good to know there is all this expertise out there.
Thanks again.
7Back to top Go down   '87 K100rs left me stranded. Empty Re: '87 K100rs left me stranded. Tue Aug 30, 2016 12:39 pm
kauaiwoodcock
kauaiwoodcock
RicK G wrote:Pull the plugs and find out if it is 1 or more cylinders flooding
Looks like only one cylinder. third one from the front.
