1 Two small issues Tue 15 Nov 2016, 08:22
Bikesmith
Hi Friends!
I have a couple issues on an otherwise perfectly running 1985 K100rs:
Issue 1) The idle fluctuates. The bike mostly idles smoothly at about 975rpm. Every few seconds, though, it will briefly drop lower. It'll drop to 900-925ish for less than a second and then come right back up. It's perfectly smooth while the throttle is on. The problem is at idle only. And while it's at 975, it's very smooth.
The most recent thing I did to the engine was balancing the throttle bodies. Honestly, I don't know if it was doing this before the throttle body job. As the bike gets better and better, I find that I'm focusing on smaller and smaller problems. So, maybe it's always done this and I just never noticed until now. Any thoughts?
Issue 2) Intermittent transmission trouble. Sometimes, when I try to downshift the shift lever won't move at all. If I let the clutch out, then pull it back in and try again, then the transmission usually works perfectly again.
This happens only after the transmission is fully up to temperature. Never in the first half hour of a ride. It's downshifts only. I haven't had a single missed upshift. The problem seems to be worse when I'm going downhill, though I'm not sure about that. It's intermittent enough that it's hard to pin down what makes it better or worse.
I changed the transmission oil 1500 miles ago and put in Castrol Syntrax Limited-Slip 75W-90. The transmission doesn't leak and the oil still looks like new. No darkening, no metal dust. I tried adding a little bit more oil. I took the oil level up from just below the line on the dipstick tool to just a touch above the line. That helped, actually. The problem doesn't happen as often now, but it still happens.
Hopefully this is an easy fix, rather than the beginning of the end of my transmission. What do you think?
Many thanks as always!
-Jon
-Jon
Jon
Mechanically competent, electrically perplexed
1985 BMW K100RS
1959 BMW R60
1942 Chevrolet 3/4-ton Special
1940 Royal Enfield WD/CO
1975 Porsche 911S
