Error 1223 Water Temperature Wed Mar 22, 2017 8:24 pm
Old Boy
hi everybody,
I have this error from the ECU:
1223 Water Temperature.
I tested the water temperature sensor, and i think it works because at 15 degrees it gives 3K of resistence and the resistence value goes down if i warm it with a lighter.
The radiator fan works. It stars when the engine temperature is high!
But the arrow of the temperature water guage is in the red part (shows high temperature) when the engine is cold! As soon as i switch On the ignition!
What could be the problem?
I have a K100RS 1991.
Thanx
Thanx
