1Back to top Go down   Ultrasonic Cleaning Question Empty Ultrasonic Cleaning Question Fri Apr 07, 2017 12:23 am
TurboBrick
TurboBrick
I now have access to an industrial grade ultrasonic cleaner. I have a few things I'm going to clean up and post before and after pictures of. My main question relates to if you all think it would be ok to clean my turbo with this machine. The guy who has it tells me I can put the entire turbo in this cleaner and it will come out looking brand new. I want to know if this has been done before and if not why? Figured I'd ask you all first.
2Back to top Go down   Ultrasonic Cleaning Question Empty Re: Ultrasonic Cleaning Question Fri Apr 07, 2017 4:15 am
just be careful if there any ceramic parts in the turbo (id imagine there is ..
perhaps suspend the unit in the bath rather than letting it rest on any one surface
a few of us have had temperature sensors (mounted in the oilpump ) crack around the ceramic to metal mating surfaces after an ultrasonic bath letting it rest on the bottom surface (yes the highest vibration point )
so from me a yes, but with caution
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OUltrasonic Cleaning Question Au-log10
3Back to top Go down   Ultrasonic Cleaning Question Empty Re: Ultrasonic Cleaning Question Fri Apr 07, 2017 11:28 pm
The ultrasonics may do damage to precision parts of the turbo, such as bearings. It might be OK for cleaning castings but be careful with movable parts until you're sure they won't get damaged. Will you be disassembling the turbo first?
4Back to top Go down   Ultrasonic Cleaning Question Empty Re: Ultrasonic Cleaning Question Sat Apr 08, 2017 12:45 am
I would be very hesitant to use an ultrasonic cleaner until you know what is inside. Would be best to ask a turbo specialist as the industrial cleaners can really rattle things.
Bikes 2004 K1200GT 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
