Number of posts : 11679
hmm.... looks to me to be another type of valve , perhaps intended to modify the rebound of the fork leg
from what I can see so far , the red plastic bit locates into a clip type arrangement and below a spring loaded valve of sorts into the leg proper ?
the top nut removed still shows the ring retainer around the fork cap , so im guessing pretty much after market gear , rather than anything "factory "
perhaps removal of the cap ...(good luck prying that ring clip out , but should be perdy easy if you can hold the tube properly and push down on the cap against the preloaded spring internal )
you might even find some kind of brand manufacture marks on the cap once removed giving more clues to look it up ?
interesting none the less , would love to see who made it and why ..?
good luck !
