1 Fuel sending unit ideas? Sat 17 Sep 2016, 10:06
KJustin
I have an '85K with the thermoresister and 4L and 7L fuel light arrangement. I installed an Acewell speedo and its all working but the fuel gauge. I know that to get the fuel gauge working I need a float-type sending unit like that which is on the 86-on models (or something similar). I've read a number of other threads on the forum about this issue and I have some questions that I didn't find answers to. I'm trying to figure out the best way to get there and would like the collective wisdom of the group on the following ideas and questions:
1. Get an 86+ tank with the proper sending unit. I know I'll need to weld on the mounting tabs to the frame do that (or figure something else out). And I'm pretty sure I'll have to follow Robmac's instructions to modify the sending unit in his excellent article "messing with the in-tank sending unit". Is there anything tricky about switching from the existing front of tank plug to one that wires through the float-type sending unit? I assume that power to the fuel pump runs though there? The other downside to this is expense of buying a new tank.
2. Cut a hole in my existing tank and install an 86+ sending unit (or some other sending unit). I'm extremely worried that I won't be able to get it tight and I'll have leaking. Anyone ever try this?
3. Install some sort of aftermarket sending unit inside the tank (no additional holes cut in the tank). I've seen some items--both float type and solid state--that might work. I know I'll have to find a unit that sends the proper resistance for my Acewell. I see two issues both related to wiring. First, how do I get the wires out of the tank? Would it be possible to open up the thermoresister unit and tap into the wires there? I seem to recall reading somewhere that the wires inside that thing were very thin and delicate. True? Second, if that is a viable option, how concerned do I have to be about making the connections (both at the sending unit and at the thermoresister unit) gas/liquid proof. Will contact with gas result in erroneous readings or, worse, other dangers?
4. I could abandon a fuel gauge idea and just wire up a low fuel light. I'd rather have a gauge, but if I were to do this, I'd need the necessary circuit to light the light. I saw a diagram to build that in a different thread, but it's beyond my technical capabilities. I have a spare motometer cluster, so could I extract the necessary board from that to accomplish this result? If so, can anyone tell me which board it is/how to do that?
I'm always open to other ideas and solutions as well. Thanks in advance.
1985 K100 Cafe Racer (formerly an RT), VIN 0051736
