1Back to top Go down   injectors  Empty injectors Mon Jun 28, 2010 2:12 pm
Rob Roy Mcgregor
Hi again .. For my next question hope someone can point me in the rite direction, does any body know what the spray pattern coming out of the injectors looks like .. ie is it a mist or a jet of fuel injectors  Icon_question injectors  Icon_question
2Back to top Go down   injectors  Empty Re: injectors Wed Jun 30, 2010 3:05 am
Should look like a spray mist a jet is bad and indicates a malfunctioning injector. It should also be pulsing earth connection applied to the injector not continuous earth.
3Back to top Go down   injectors  Empty Re: injectors Wed Jun 30, 2010 4:44 am
Ned
Ned
definitely fine spray not mist. There is no real way for you to test the performance of the injectors. For a modest fee your local garage with the correct equipment should be able to test and clean the injectors.
Now, there is no way of fixing them. You can only clean and test the flow at the correct pressure. So, it is worth getting them cleaned and tested.
Ned
4Back to top Go down   injectors  Empty Re: injectors Wed Jun 30, 2010 10:14 am
Rob Roy Mcgregor
Thank you lads . .
5Back to top Go down   injectors  Empty Re: injectors Fri May 10, 2013 1:03 am
petek100rs
petek100rs
My son works at a nisan dealership and brought home the equipment needed to do an inboard injecter clean. It uses a wyns spray product that you tap straight into the fuel rack. The difference in power economy and throttle response is amazing. I had problems with the bike choaking randomly and this cured that problem
6Back to top Go down   injectors  Empty Re: injectors Thu May 30, 2013 1:38 pm
I see ultrasonic cleaners on ebay cheap. Wouldn't these chase out the gremins?
7Back to top Go down   injectors  Empty Before Thu May 30, 2013 2:32 pm
ibjman
ibjman
Before making any moves, I would get a bottle of Chevron "Techron" and run a strong solution of it through 1 tank of fuel.......assuming the machine is drivable........getting as much wide open throttle-heavy load running as practical. This stuff works very well.
A good idea of spray ability..... can be had by pulling the entire fuel rail with nozzles attached and just tipping the nozzles slightly out away from the engine. With the ignition coil "Primary wires" unhooked to prevent sparking, hold a flat piece of cardboard about 5" below the nozzles and crank the starter over a couple of turns.
A resulting pattern on the cardboard that's a nice round dark spot about 2" across shows pretty well that the injectors should be useable.
Proper cautions for fire danger are essential.
8Back to top Go down   injectors  Empty Re: injectors Thu May 30, 2013 7:18 pm
club_c
club_c
+1. Ask me how I know...
1988 K100RS SE VIN 01477554
9Back to top Go down   injectors  Empty injectors Fri May 31, 2013 7:05 am
I'd like to inject a variation please. Today I took some spare injectors to a shop to get cleaned and new o rings etc. They insisted on adding new tiny filters to the fuel rail end of the injector, saying that it was imperitave and would have been originally fitted. I have pulled out 3 sets of injectors from old K's and haven't seen one with a filter fitted.
Anyone got any thoughts? please. My Blue Max 85 RT has done 25,000 klm without these things in. Should I be worried, as they need to put installed with a special tool apparently. Sending photo's after I pick them up.
10Back to top Go down   injectors  Empty Re: injectors Fri May 31, 2013 7:12 am
They should be there and I am supprised that some didn't have them. Usually when you do an injector it's two O rings and a filter.
Bikes 2004 K1200GT 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
11Back to top Go down   injectors  Empty Re: injectors Fri May 31, 2013 7:19 am
@RT wrote:Anyone got any thoughts? please. My Blue Max 85 RT has done 25,000 klm without these things in. Should I be worried, as they need to put installed with a special tool apparently. Sending photo's after I pick them up.
I'm surprised none of your injectors have had filters fitted. The filters are required IMO. They are the last defense from dirt in the fuel and ensure a long life for the injector's internals. Read this post.
I wouldn't believe what you've been told about the tools. The special insertion tool is a hammer and the special extraction tool is a #8 screw clamped in a vice. The process is very simple and you can recondition a set of 4 injectors with new O-rings, filters and end-caps in an hour or so.
12Back to top Go down   injectors  Empty Re: injectors Fri May 31, 2013 8:00 am
aye ...indeed rob ...+1
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Oinjectors  Au-log10
13Back to top Go down   injectors  Empty They are tiny & hard to see Fri May 31, 2013 3:21 pm
ibjman
ibjman
They are TINY little oblong mesh screens that are kind of "pressed down" into the hole in the center of the inlet hole.
They can appear to be part of the injector itself. I think they incorporate a brass ring around the center of the top edge.
Look closely directly down in to the top of the injector with a bright light.....I'm guessing they are there.
Usually a screen can be extracted with just the correct size sheet metal screw lightly started down into the center of the top hole and then pulled out (on the end of the screw) with a very firm tug from a pair of pliers.
It helps to identify them if you can see a new one before it's installed.
injectors  Kgrhqr10
14Back to top Go down   injectors  Empty Re: injectors Fri May 31, 2013 8:38 pm
This is what some of us here on the forum have used...comes in a kit on Fleabay .
injectors  507791469_tp
15Back to top Go down   injectors  Empty injectors Sat Jun 01, 2013 5:23 am
Thanks, I just know I will get ripped off as the older guy I dealt with before has retired
(did me a price favour as he liked the bike). 3 of the injectors came back from them without caps or o rings or filters last time, although they now deny having done the work.
Anyway, all part of the conspiracy to keep RT poor. All I want is to get the new bike started.
Cheers RT
16Back to top Go down   injectors  Empty Re: injectors Sat Jun 01, 2013 7:38 am
new bike ???
oops i tripped again ....when did this happen bob ?
17Back to top Go down   injectors  Empty Re: injectors Sat Jun 01, 2013 11:31 am
Hey RT, I have four injectors here ready to go (new O rings, caps, filters) if you want me to send them to you.
PM me.
18Back to top Go down   injectors  Empty injectors Sat Jun 01, 2013 8:30 pm
Well Charlie it's a few months ago, bought a clapped out 91 LT with RT fairing and belonged to a one legged rider so gear shifter was improvised, leaks around fork seals, valve cover, rear brake line and has real short suspension . But was black and I'm hoping to do it naked. (maybe in summer). Fires but wont start, injectors looked bad but I have it almost ready to test fire again.
Thanks Blakey I'll send PM.
19Back to top Go down   injectors  Empty Re: injectors Sat Jun 01, 2013 8:33 pm
wow ...good work mate ....
youll have lots of fun i expect
20Back to top Go down   injectors  Empty injectors Sat Jun 01, 2013 8:45 pm
Fun? Charlie.
Expecting major frustrations and stress but am looking forward to it. Started a resto thread a while ago but been working on the other beast meantime. Finally got the crankcase cover sealed and all hoses replaced. It's been fun with everybody's help. Now it's raining so can finally concentrate on pulling bits off.
