1Back to top Go down   Clacking front brakes? Empty Clacking front brakes? Tue Oct 03, 2017 5:12 pm
boostd4
boostd4
I've got some noise coming from what I think to be my front brakes.  It only happens when I'm cruising or coasting (not applying brakes).  It's clacking noise from the front end over bumps and road irregularities (though perhaps not specifically bumps, just any jostling of the front forks).
If I squeeze the front brake lever and apply just a little bit of pressure, the clacking stops (even if the road is bumpy - ruling out forks/steering head).  The brakes work well - I bled them today without issue (not related - installed clipons and had to disconnect the brake line - has been clacking long before them).  I popped the cover on the caliper and everything appears in place (see photo).  My brake discs are of the vertical slot type.
Is this normal?  Any suggestions?
Clacking front brakes? VhpKFtJ
Clacking front brakes? ZSBNiSB
2Back to top Go down   Clacking front brakes? Empty Re: Clacking front brakes? Tue Oct 03, 2017 5:52 pm
nino found it ...
downtube through the steering head , vibrates
a touch of silicon to hold the tube in place ...mine disappeared
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OClacking front brakes? Au-log10
3Back to top Go down   Clacking front brakes? Empty Re: Clacking front brakes? Tue Oct 03, 2017 5:53 pm
boostd4
boostd4
What tube?
4Back to top Go down   Clacking front brakes? Empty Re: Clacking front brakes? Tue Oct 03, 2017 6:23 pm
Clacking front brakes? 20171010
happens at the bottom knuckle
here
Clacking front brakes? 20171011
5Back to top Go down   Clacking front brakes? Empty Re: Clacking front brakes? Tue Oct 03, 2017 10:59 pm
Also quite possible the pads are cheap or non OEM and they are a wee bit small so rattle but when you apply pressure they are held firm against the  front of the caliper.
Bikes 2004 K1200GT 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
