1Back to top Go down   Steering head removal Empty Steering head removal Sat Nov 11, 2017 2:32 am
Just a query for those more in the know .
I am looking at swapping over the front forks and triple tree from an 87 K100RT to K100LT, and vice versa .
The K100LT will be used for display purposes only , not to be ridden again , as this frame has been written off by insurers.
The K100RT is hoped to get a make over, naked of sorts , to provide more airflow .
My question : can I remove the forks complete with triple tree as one complete component . what is the process to do so .
Thanks Ed.
Steering head removal 10_x_110
2Back to top Go down   Steering head removal Empty Re: Steering head removal Sat Nov 11, 2017 2:58 am
The steering head and bearings are the same. It's a very easy swap Ed
3Back to top Go down   Steering head removal Empty Re: Steering head removal Sat Nov 11, 2017 6:49 am
.... and even easier if you just leave the triple clamps in place and swap the forks.
 Steering head removal Austra12    Fuel:  95 Octane
4Back to top Go down   Steering head removal Empty Re: Steering head removal Sat Nov 11, 2017 9:35 am
easy peasy  Ed
5Back to top Go down   Steering head removal Empty Re: Steering head removal Sat Nov 11, 2017 4:12 pm
Holister wrote:.... and even easier if you just leave the triple clamps in place and swap the forks.
Thanks guys .
My thoughts exactly Nigel .
The front wheel on the RT is literally glued on , due to somebody ( not me) using locktite on the front bearing .
 Which as it heated up spread to the axle , making axle removal difficult . So the remedy is to swap it to a non working bike .
