1Back to top Go down   Water pump impeller Empty Water pump impeller Sat Dec 23, 2017 4:13 pm
Hello all
I have a question on removing the impeller from the shaft
I have removed the bolt from the shaft but i cant get the impeller to come free from the shaft
The impeller is a cast type i dont need to keep it as i have brought a new one and shaft for the rebuild
2Back to top Go down   Water pump impeller Empty Re: Water pump impeller Sat Dec 23, 2017 7:35 pm
Put a long bolt into the shaft and holding the pump in your hand tap the shaft through by tapping the end of the bolt. it should push the shaft out of the pump and release the impeller.
Bikes 2004 K1200GT 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
3Back to top Go down   Water pump impeller Empty Re: Water pump impeller Sun Dec 24, 2017 9:53 pm
Thanks Rick
Seems simple now but could not find the answer anywere
4Back to top Go down   Water pump impeller Empty Re: Water pump impeller Sun Dec 24, 2017 10:17 pm
hang onto that shaft Mathew sounds like its one of the later ones
and merry christmas
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OWater pump impeller Au-log10
Hello all
So Im about to start the reasmble on the water pump and need to get the gasket sealant
I have been looking at buying the threebond sealant but not sure which one is required
www.threebond.com.au
The other option is the locktite superflex Blue RTU
And how much do you need to buy ?
Thank you for all your help
6Back to top Go down   Water pump impeller Empty Re: Water pump impeller Mon Jan 01, 2018 8:18 pm
I'm pretty sure I have a tube of 1104 in the garage but I'm too lazy to go and look (it's pissing down outside). One 200g tube will last you for years. So far, mine's helped put together some dozen or more bikes over the last five years and it's still more than three-quarters full. It's even stopped ancient British bikes from marking their territory...
[Edit] Dammit, you made me go and look. It's a 200g tube of 1184 - search ebay.
7Back to top Go down   Water pump impeller Empty Re: Water pump impeller Mon Jan 01, 2018 10:19 pm
If you can get Permatex in your part of the woods, then try Permatex® Anaerobic Gasket Maker (51817 for the 6ml size and 51813 for the 50 ml size).
8Back to top Go down   Water pump impeller Empty Re: Water pump impeller Mon Jan 01, 2018 11:02 pm
whatever you use Mathew ....just a smear is all that is required on the pump housing , wait for it to start going off before introducing the 2 faces
then bolt it up with just enough force to seal the faces in a cross point fashion (ie one side then the other ), initially , then go around and tighten again once it has squeezed some out the faces .
leave for at least 24 hours after
I hear lately of many stories of too much sealant being used , some collecting into the oil lines with disastrous consequences  it seems particularly prevalent on k1100s
good luck
9Back to top Go down   Water pump impeller Empty Re: Water pump impeller Tue Jan 02, 2018 6:34 pm
Hello all
Another quick question
How do you torque up the impler bolt without pulling the shaft further though the seal ?
Im happy with all the clearences and the back of the drive gear is flush with the out side surface
Plus the front face is close but not touching the housing
Im happy with the clearences the impler sit off.
But the impler bolt is not tight and what torque setting should this be ?
I have read in the threads that if you over tight you end up breaking ths seal
10Back to top Go down   Water pump impeller Empty Re: Water pump impeller Tue Jan 02, 2018 7:32 pm
Once the shaft is pulled through the bolt only tightens the impeller to the end of the shaft and wont put any more stress on the seal.  tension 15-16ft/lb and the factory say to use red Loctite but I use the blue thread locking stuff because it is a bit easier to get undone when needed.
11Back to top Go down   Water pump impeller Empty Re: Water pump impeller Tue Jan 02, 2018 7:55 pm
Thanks rick
So i just keep doing the bolt up
12Back to top Go down   Water pump impeller Empty Re: Water pump impeller Tue Jan 02, 2018 8:30 pm
Water pump impeller 112350
13Back to top Go down   Water pump impeller Empty Re: Water pump impeller Wed Jan 03, 2018 9:05 pm
Well I bont get my badge for fixing the water / oil pump first go
I have oil leaking out the cable pathway hole for the water temp point
I belive that this must mean the pump block is not sealed against the engine block
I have photo on my phone on the sealant used and how much was applied
Looks like another oil change and coolant change
14Back to top Go down   Water pump impeller Empty Re: Water pump impeller Wed Jan 03, 2018 9:37 pm
They are a bit finnicky like that. If you get the centre stand on a 2" block and tilt the front up you wont lose much oil if any.
I have had to do it twice a few times to stop the drips but it's usually the front plate.
