1Back to top Go down   How do you remove these? Empty How do you remove these? Thu Feb 08, 2018 5:22 pm
philbuck
philbuck
I want to remove the grill to respray the fairing, but there are 4 of these little monkeys holding it on. Anyone ever had any success in removing them, without destroying anything?
How do you remove these? Imag0013
2Back to top Go down   How do you remove these? Empty Re: How do you remove these? Thu Feb 08, 2018 8:36 pm
I've removed them successfully by using a jewelers screwdriver to pry the leaves back away from the post they are anchored against.  It destroys the fastener, but you really want to use a new one anyway.
3Back to top Go down   How do you remove these? Empty Re: How do you remove these? Fri Feb 09, 2018 4:50 am
if you can pry one edge up . then a good set of side cutters can cut through the outer flat section of the fastener , yes it destroys it but also widens the section allowing easy removal with just a twist to widen the whole thing ... you do save the plastic bolt section from too much damage doing it this way
they are available from any good bolt store shop as replacements
4Back to top Go down   How do you remove these? Empty Re: How do you remove these? Fri Feb 09, 2018 5:03 am
philbuck
philbuck
charlie99 wrote:if you can pry one edge up . then a good set of side cutters can cut through the outer flat section of the fastener , yes it destroys it but also widens the section allowing easy removal with just a twist to widen the whole thing ... you do save the plastic bolt section from too much damage doing it this way
Thanks for that, I'll give it a go.
