1 K100 starts and dies Mon Aug 27, 2012 8:14 am
GeorgeW50
Hello all, my first post, requesting some technical help and guidance please.
I’ve had my 1984 K100 for 13 years, but it has never given me any reason to learn the details of its operation – it has been virtually faultless. It has nearly 120,000 miles on the clock and has now developed a running fault.
In brief, it starts instantly as it always has done, but then dies after 2 or 3 seconds, sometimes less, occasionally a little longer, as long as you don’t touch the throttle. When running it sounds normal and all four exhaust down pipes warm up to the same degree.
The first time it did this, I had to just put it back in the garage as I was on a mission. The next day, having decided that maybe it was the injection ECU connector, I wiggled the same and tried again whereupon it burst into life. Unfortunately the next time I tried to start it the problem had returned. Since then, while troubleshooting at intervals over the last few weeks it has twice cured itself somehow: the first time I then went for a 30 mile ride without incident, but it failed again at the next start. I’m sure that again this was subsequent to very firmly seating the injection ECU connector, but I’ve tried that many times since to no avail. The second time it started and ran normally for a couple of minutes before cutting out again. Otherwise, the symptom is always the same: instant start and then die.
I have been guided in my trouble shooting mainly by the excellent document and interactive wiring diagrams created by Bertrand Vogel, as well as the existing posts for similar problems on this forum, though none seem to quite match mine, in the very short time the engine runs before it dies. I’ve also had some helpful suggestions from the UK BMW club forum.
I did find a couple of faults: an earth wire adjacent to the vacuum switch was broken from its terminal, and the clutch switch was not working. Repairing the wire and replacing the switch made no difference to the main problem.
The situation is as follows:
Fuel supply
It has a full tank of fresh Shell petrol – the last journey before the problem started was the mile back from the filling station (I should say “had”, because I got fed up of lifting a full tank and removed some). The pump runs on pressing the starter button and the fuel pressure is 2.5 bar. While the engine is turning the pressure oscillates between 2.5 and 2.3 bar, presumably as the injectors open and close. When the engine stops the pressure returns to 2.5 bar, the pump then stops and the pressure then drops away. I have a professional quality Muller Bem 10 bar pressure gauge intended for hydraulic systems, but it does the job. I have disconnected the return from the regulator and allowed it to discharge into an open receptacle: there is good flow as well as pressure. The fuel filter was replaced 13,000 miles ago (normal replacement interval: 20,000 miles ?)
All four injectors spray fuel when turning over the engine; the spray patterns look uniform.
Electrical checks
Following Bertrand’s procedure, I can confirm that:
The earths on the gearbox and under the tank are clean and tight. I have also cleaned the starter motor commutator and brushes. The starter was actually really very clean inside, thought the brushes are well worn – I’ll replace them later.
Both Hall sensors are working when checked using Bertrand’s LED test. I have another set which also test OK. I substituted this set on the engine: no change.
The voltages and resistances given at the ignition module and the injection ECU conform to Bertrand’s indications – only one is slightly different: at line 4 of the injection ECU I get only 10.4V with the starter relay disconnected and only 7.1V with the starter running, even though the battery voltage only drops to 10.5V. The ignition signal voltage of 20mV is present at line 1 of the injection ECU when the engine is turning. I used a Fluke 75 meter for the checks.
I have manipulated the wiring harness while carrying out continuity checks looking for a broken wire or bad connection – nothing to report.
I have substituted the following parts from my stock, without any change in behaviour:
Ignition controller
Hall sensors
Air flow meter (with its air temperature sensor)
Water temperature sensor
The original parts are now back on the engine.
I don’t have another injection ECU to try, but I have opened mine and did not find anything loose or traces of corrosion.
Both pairs of plugs seem to be sparking strongly.
With a strobe timing light connected to No 1 plug lead and a 12V LED across No 4 injector terminals, both systems seem to be working: I have both sparks and injection.
With the plugs out and in 5th gear, ignition on, turning the rear wheel produces sparks at alternate pairs of plugs, pulses from the fuel pump and pulses at the injectors (tested with an LED across the terminals).
The pump stops and the injection relay opens after the engine has stopped. However, keeping the starter button pressed does allow the engine to keep running (albeit with a protesting starter motor). This would seem to be the principal finding and I understand that this richens the mixture as well as presumably providing an earth for the injection relay etc, though this does not seem to be needed.
An un-metered air leak? It doesn’t seem to fit the nature of the problem: either running perfectly (although rarely) or the start-and-die routine. Anyway, the breather hose at the back of the engine is nearly new and in good condition - I replaced it recently to cure a problem of poor running at low speed. I have carefully examined the air box above the butterflies, but have not removed it – nothing to report. I have tried spraying contact cleaner and also methylated spirits around the butterfly bodies while starting – no effect
Most things I’ve checked more than once but I’m getting nowhere. Can anyone see what I’ve missed? I would very much appreciate some help.
Fuel supply
Electrical checks
Ignition controller
Hall sensors
Last edited by Crazy Frog on Mon Aug 27, 2012 8:52 am; edited 1 time in total (Reason for editing : Replaced micro font with regular one (Fixed Inge's problem :-) ))
