1Back to top Go down   remove side stand bushing Empty remove side stand bushing Thu Mar 29, 2018 4:37 am
mister_anger
mister_anger
hello,
I need to renew the side stand bushing but ...
It seems that the side stand and the bracket, where you mount the stand, both have a bushing.
The one in the bracket is not playing ball.
On the side of the bracket where you insert the bushing I see a little hole but I can't tell if this holds a screw of some sort to keep the bushing in place.
In this picture you can see the bushing the needs to be inserted in the side stand bracket (or so I think). Is it just a matter of pushing the old one out?
thanks,M
thx,Mremove side stand bushing Bmw_k110
2Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Thu Mar 29, 2018 5:19 am
It should only be a bushing in the bracket.
The small hole is for lubricating, using a grease gun with a pointed tip.
3Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Thu Mar 29, 2018 6:16 am
mister_anger
mister_anger
thank you for the info
4Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Thu Mar 29, 2018 6:31 am
BobT
BobT
The little hole on mine is connected to a normal grease nipple.
5Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Thu Mar 29, 2018 6:46 am
mister_anger
mister_anger
Ok, thanks.
I am thinking of removing the center stand and only keep the side stand.
The K100 does not like the side stand because of the issue of oil going to the cylinders when it stand on the side stand to long.
Extending the side stand seems best then.
Any info on that?
6Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Thu Mar 29, 2018 7:12 am
BobT wrote:The little hole on mine is connected to a normal grease nipple.
A grease nipple was used on later models.
On early models the small hole is drilled in the mounting bracket.
Later models have a distance sleeve underside of the bolt head (and a longer bolt)
where the grease nipple is mounted.
7Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Fri Mar 30, 2018 12:14 am
mister_anger wrote:I am thinking of removing the center stand and only keep the side stand.
Any info on that?
The smoke that might be created by leaving the bike on its side stand is only temporary; as a bonus, it keeps the mosquitoes and midges away.
It seems to me that if you attempt to make the bike more vertical when on its side stand, all you will be doing is making it more likely to be tipped over in the opposite direction, either intentionally or accidentally. As long as it is tipped at all, some oil will still be seeping into the combustion chamber.
When parked on pavement at its typical side stand angle, it takes some real effort to knock it over.
8Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Fri Mar 30, 2018 1:01 am
search in the forum for sidestand puck
might help
there is a procedure for sidestand parking that not always , but regularly lessens the chance of smoking
good luck
9Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Fri Mar 30, 2018 4:28 am
Suzi Q
Suzi Q
The smoke is there so's they can't see you as you escape.
remove side stand bushing Josef15 Ja
remove side stand bushing Stefan19 Ja
10Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Fri Mar 30, 2018 5:54 am
omg Chris
fell of my chair laughing ...thanks for brightening up my week
nearly as funny as me trying to start the bike today , which wouldn't start , blast ,,,and I nearly stubbed my toe on the maf lying on the ground on the other side of the bike , looking for the reason ...
the air box is still hanging under the awning waiting for the paint to dry
ill just leave that here with you to think about
11Back to top Go down   remove side stand bushing Empty Re: remove side stand bushing Fri Mar 30, 2018 7:45 am
Suzi Q
Suzi Q
That's unreal.
The week gone, I tried to start my K100 after wheeling it into the workspace. Kept firing but wouldn't run.
Following day realised I'd 'borrowed' the MAF a while ago to try it on the MadAss.
They don't run without MAFs do they?
Uncanny. Transcontinental dumbness, the international language of bikers.
Glad the post made you laugh, have fun.
