George_Pap
George_Pap
Got a melted green plug behind my instruments cluster. Is there any available?
Thank you
K100RT (Early 1985 -nonABS)
Try this guy in Europe (He's in Corsica):
Instruments cluster Green Plug Needed Sans_t11
Instruments cluster Green Plug Needed Frog15Instruments cluster Green Plug Needed Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
George_Pap
George_Pap
Crazy Frog wrote:Try this guy in Europe (He's in Corsica):
Instruments cluster Green Plug Needed 112350 Instruments cluster Green Plug Needed 112350 Instruments cluster Green Plug Needed 112350
How to get the pins out:
1. Look very carefully at the small cutout next to the individual terminals. You need to make a tool with a blade that is no bigger than this (length x width) and about 20mm long.
2. Push the tool carefully into the cutout and push the tip of the tool down gently. This should depress the latch on the terminal.
3. Pull on the wires to slide the assembly out.
If you push down too hard you will destroy the terminal. New ones are available, but in quantities of 100 only from RS Components in the UK. See here:
https://uk.rs-online.com/web/p/pcb-connector-contacts/5091994/?searchTerm=509-1994&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D626572266C753D656E266D6D3D6D61746368616C6C26706D3D5E285C647B362C377D5B4161426250705D297C285C647B337D5B5C732D2F255C2E2C5D5C647B332C347D5B4161426250705D3F292426706F3D3126736E3D592673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3530392D31393934267374613D3530393139393426
Note that the price shown is ex-VAT and ex-P&P.
PM me for the connector block - I've got a couple of spares.
Dai wrote:New ones are available, but in quantities of 100 only from RS Components in the UK.
If you don't need 100 female contacts bounce , you can get them single
from BMW...part # 61 13 1 459 104.
