1Back to top Go down   K1100 cam chain replacement Empty K1100 cam chain replacement Mon May 07, 2018 3:50 am
Packo
Packo
I want to replace the cam chain on a K1100 but am unable to find much info using the search function nor can I find a you tube video.
Both the Clymers and BMW Repair manual refer to the special BMW tool 11 3 700 - camshaft setting tool - in the cam chain installation section but I suspect this is only used after the camshafts have been removed. How important is this tool and can the job be done without it, whether or not the camshafts have been removed.
Hopefully, the valves clearances will not need adjusting so no need to remove the camshafts but best to be prepared for that while I am in there.
Please advise ???
______________
83 K100 HRD Outfit
77 R100RS
1992 K1100 Outfit
1983 K100
2Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Mon May 07, 2018 8:43 am
To do the chain you don't need that tool, it holds the adjuster back so the chain can go back onto the sprockets but you will have the adjuster off the engine and wont need to use it. I cleaned the adjuster and put it back together then used a wire twitch to keep it compressed till the chain was on the sprockets and tension rails then cut the wire and pulled it out.
Actually duck has a bit about doing the cams using a screwdriver and a string to hold the tensioner on his site.
3Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Mon May 07, 2018 9:09 am
The tool in question is for locking the camshafts in position.
But that won't be needed either, use the alignement marks on the crank and sprockets.
4Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Mon May 07, 2018 11:13 am
Should have known that was the tool in question. I have one of those if needed I can post it down.
Inge I think you are a bit like TWB and the numbers are burnt onto the eproms of your brain. Does it go sizzle when they are burnt on Very Happy
5Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Mon May 07, 2018 12:20 pm
Why do you want to replace the cam chain? Are you some sort of masochist?  Shocked
6Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Mon May 07, 2018 10:02 pm
Packo
Packo
RicK G wrote:Should have known that was the tool in question. I have one of those if needed I can post it down.
Thanks Rick, I will see how I go without it first and if I get into trouble will let you know
Inge indicates it is not necessary and he hasn't steered us wrong yet
______________
83 K100 HRD Outfit
77 R100RS
1992 K1100 Outfit
1983 K100
7Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Tue May 08, 2018 10:41 am
RicK G wrote:Inge I think you are a bit like TWB and the numbers are burnt onto
Nah, had to look it up.......but I've had a idea after reading the first post.
If TS is afraid that the cams could move during the process, you can use
some of white zip ties to keep them in position.
I'm quite shure that Blakey would be very happy to send you a some,
he must have more than plenty of them.
K1100 cam chain replacement Drev11
8Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Tue May 08, 2018 11:58 am
duck wrote:Why do you want to replace the cam chain? Are you some sort of masochist?  Shocked
Same opinion: no need to change before a long, long,very long mileage. 2 or 300 000.
9Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Tue May 08, 2018 12:08 pm
Inge makes a good point.  Only white zip ties are suitable for this task.  Black ones won't cut it.
10Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Tue May 08, 2018 12:41 pm
Finally white zip ties have the approval of the forum...brilliant idea.
1983 K100RS 0011171 Fricka 606 Alaska Blue 29,495 miles Damn K Pox Its a Bat outta Hell Now 49,840 miles.
11Back to top Go down   K1100 cam chain replacement Empty Re: K1100 cam chain replacement Tue May 08, 2018 8:45 pm
92KK 84WW Olaf wrote:Finally white zip ties have the approval of the forum...brilliant idea.
Only where they can't be seen when in use.   K1100 cam chain replacement 652573
