1Back to top Go down   Wheel/Tyre Valves Empty Wheel/Tyre Valves Mon May 14, 2018 8:48 am
@kustom_moto
@kustom_moto
Hey guys,
Ok hoping someone can help me, I have an early '84 K100 RS and need 8mm wide tyre valves. The ones I ordered from BMW have a thread length of only 20mm which only leaves about 8mm poking out for air to go in. The one that came off was 30mm but I want a new pair with new rubber o rings.
Is it ok to use a 20mm or should I continue to hunt down a 30mm? BMW Motorworks only keep the 20mm thread. Were the wheels changed slightly around my year?
2Back to top Go down   Wheel/Tyre Valves Empty Re: Wheel/Tyre Valves Mon May 14, 2018 9:57 am
Ant tyre places will have what you want don't need genuine stuff for that.
3Back to top Go down   Wheel/Tyre Valves Empty Re: Wheel/Tyre Valves Mon May 14, 2018 10:33 am
@kustom_moto
@kustom_moto
You cant just buy these off the shelf from any tyre place, they are 8mm wide and need a 30mm thread. If you mean a normal car tyre valve it won't even go through the hole......
