1Back to top Go down   Seat bracket help wanted Empty Seat bracket help wanted Fri May 18, 2018 8:15 am
DeRodster
DeRodster
Ok here goes
My machine is a '92 K1100lt and in fine shape
But
 I have a spare  saddle from a later model (post '93) that i would like to use...
The problem i am having is with the rear bracket on later saddle as it appears to be lower (shorter) by about a half inch ( sorry, I'm pre-decimalisation) and makes it awkward to pivot the saddle up. The seat mouldings are quite different actually.
I wonder if any of you could tell me the bracket part number as i am having difficulty finding it
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   Seat bracket help wanted Empty Re: Seat bracket help wanted Fri May 18, 2018 8:17 am
DeRodster
DeRodster
I should say that i have tried to fit my current rear bracket to the newer saddle and thats when i reasised the problem.  ?
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
3Back to top Go down   Seat bracket help wanted Empty Re: Seat bracket help wanted Fri May 18, 2018 8:19 am
The later bikes had about a half inch of rubber in the mounting brackets.  You can make things fit by adding your own about 1/2" spacers.  Been there, done that.
ETA: They don't have to be rubber spacers.  I used HDPE. (Plastic)
4Back to top Go down   Seat bracket help wanted Empty Re: Seat bracket help wanted Fri May 18, 2018 8:21 am
Front: 52 53 2 307 568
Rear: 52 53 2 307 572
5Back to top Go down   Seat bracket help wanted Empty Re: Seat bracket help wanted Fri May 18, 2018 8:24 am
Hi Rod
As already mentioned the later seats had rubber in the front and rear mounting bracket's.
Take a look at this page
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=UA&SbCt=BA_15_40_UA_50
Seat bracket help wanted Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 60K Km     ;BMW;  K1100RS Black 1996       ;BMW; K1 Blue 1990 25K Miles
6Back to top Go down   Seat bracket help wanted Empty Re: Seat bracket help wanted Fri May 18, 2018 8:51 am
DeRodster
DeRodster
Go raibh maith agaibh, Merci, Gracias, Thank you
This is why this site is of such great value to us K'ers, I knew I just had to ask
Ordering now ( I could try that Duck , but just want no hassle fitting if poss !)
Slán
Rod
well as soon as they get back from lunch ;-)
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
