1Back to top Go down   Stripped valve cover thread Empty Stripped valve cover thread Tue May 29, 2018 7:35 pm
Packo
Packo
I have a couple of stripped threads in the bearing caps for the valve cover bolts
To insert the helicoil should I remove the bearing cap or do the job in situ ???
Mike
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
2Back to top Go down   Stripped valve cover thread Empty Re: Stripped valve cover thread Tue May 29, 2018 9:40 pm
You can do the job in situ - just pack a piece of cloth around the area to catch the swarf and be assiduous in cleaning it out afterwards. The other possibility if you prefer to remove the cap is to rotate the engine until that cylinder is at TDC on the firing stroke i.e. there's no pressure on the cam cap. The advantage of removing the cap is that it will be easier to get the drill in the correct position to clean the old threads. I think I'd go this route.
Also: be very, very, very careful because the cam caps are cast from mouldy cheese and the threaded area will break up at the slightest provocation.
3Back to top Go down   Stripped valve cover thread Empty Re: Stripped valve cover thread Tue May 29, 2018 11:00 pm
Sidecar Paul also designed this as a fix
Stripped valve cover thread Cam_bl10
4Back to top Go down   Stripped valve cover thread Empty Re: Stripped valve cover thread Wed May 30, 2018 4:09 am
Packo
Packo
Thanks Dai & Rick, job done, removed caps and did it on the bench. Don't think it took much longer than doing it on the bike really
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
5Back to top Go down   Stripped valve cover thread Empty Re: Stripped valve cover thread Wed May 30, 2018 1:38 pm
RicK G wrote:Sidecar Paul also designed this as a fix
Got that downloaded and saved...
