1Back to top Go down   ABS brain change Empty ABS brain change Fri Jul 13, 2018 8:49 am
PiotrK100
PiotrK100
I just make sure that my computer (ABS brain) is dead because of code 7. I checked all other possibilities that can cose that problem and all is perfect but code 7 stays. It is broken. Now, I did found on internet in PL computer for reasonable price but some descriptions on box are different.
My is ABO2.5 and the other is ABO1.5. Have no idea what is the diference it makes. Will 1.5 fits my 2.5??
ABS brain change Aac54811
ABS brain change Wp_20115
http://www.xenum.pl
2Back to top Go down   ABS brain change Empty Re: ABS brain change Fri Jul 13, 2018 9:15 am
No they are not interchangeable apparently the wiring is a bit different.
Have you tried resetting the brain?
Go here and have a look and contact Tosi http://bmwk10075abs1fix.web.fc2.com/  he knows a lot about them.
3Back to top Go down   ABS brain change Empty Re: ABS brain change Sat Jul 14, 2018 6:14 pm
PiotrK100
PiotrK100
RicK G wrote:No they are not interchangeable apparently the wiring is a bit different.
Well, I was trying all "tricks" also from Toshi website. It is no other way now just code 7 which is a brain. I wish I'm wrong.
http://www.xenum.pl
4Back to top Go down   ABS brain change Empty Re: ABS brain change Sat Jul 14, 2018 7:36 pm
Yes, the wiring is different.  To make a K1100 ABS brain work with a K75 wiring harness on a K75 with a K1100 front end I had to move the power pin to a different spot in the connector.  Also the front sensors are different between the 2V ABS and 4V ABS.
