@kustom_moto
@kustom_moto
Guys, I have just had a fantastic new paint job done on the tank but came into the garage this morning and it's leaking, I have the tank off now and have tracked this hole down.
Pinhole in tank, can it be repaired? HELP! 20181110
Now question is, is there anything I can use to plug this? Was thinking possibly JB Weld? Is there anything else? Last resort is have it welded shut and also use a tank sealer. Then it will need respraying too :-( nightmare!
1988 K100 LT
1984 K100 RS
Instagram K100 Build follow me at: @kustom_moto
https://www.ebay.co.uk/itm/VersaChem-HEAVY-DUTY-Fuel-Tank-Repair-Kit-Petrol-Diesel-Leak-Fix-Seal-n-Place-/263901820022?hash=item3d71c63476
https://www.ebay.co.uk/itm/Heavy-Duty-Fuel-Tank-Repair-Kit-Petrol-Diesel-Leak-Fix-/323456504503?hash=item4b4f8292b7
I've patched LFB's tank twice now with the top stuff, once because of corrosion and once because of damage at the front of the tank after the PO was t-boned.
Oh - and check the other side of the tank in the same place.
Woodie
Woodie
I've made the same type of repair as Dai on my tank.  I didn't purchase a specialised product because I had polyester resin on hand.  No issues with the repair so far.
Pinhole in tank, can it be repaired? HELP! Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
@kustom_moto
@kustom_moto
That's great guys, thank you. Since I posted I have now lost confidence in the tank, I suspect there could well be other small holes so have emptied the gas and will have it welded, if I cant weld then will use this stuff and also line the tank and have it resprayed.
Can anyone recommend a decent lining kit?
1988 K100 LT
1984 K100 RS
yamaguzzi
yamaguzzi
Caswell epoxy gas tank sealer is what I use for this kind of problem.You need to be careful if you live in the US where they contaminate all our fuel with ethanol .That crap can eat thru a lot of products but this will stand up to it
https://www.caswellplating.com/epoxy-gas-tank-sealer.html
Woodie wrote:I've made the same type of repair as Dai on my tank.  I didn't purchase a specialised product because I had polyester resin on hand.  No issues with the repair so far.
I also used a polyester resin with glass fibre on a steel boat fuel tank 25+ years ago. (Multiple pin holes on the flat bottom.) My son still has the boat and it is still sound. Maybe 15 years ago, similar on a steel small Yamaha bike tank.
Only caution: ethanol fuel will likely affect it, so another good reason not to use E10 or similar.
