Hello All
I have been having trouble with trying to get my rear main seal  / output shaft seal to stop leaking
I believe that it may have something to do with the stop disk/ thrust washer  and how it passes through the seal
Item number  10
[b][b]11 21 1 460 873[/b][/b] STOP DISK - 1MM
or
[b][b] 11 21 1 461 813[/b][/b] STOP DISK - 1,25MM
Is this item required  ?
Stop Disk,Thrust washer behind the clutch basket  K100 only  Img_1610
Stop Disk,Thrust washer behind the clutch basket  K100 only  D5430d10
Matthew Brisbane wrote:Item number 10. Is this item required?
A K100 like yours has one; the K75 doesn't have one. I suggest you keep it in the assembly. If it's damaged, measure its thickness and replace it with an OEM washer/stop disk of the same thickness.
What is that a strand of material visible in the lower part of the second image?
Last edited by Laitch on Tue Feb 26, 2019 6:17 am; edited 5 times in total (Reason for editing : Improved artistic rendering)
