2 Re: Mystery Nipple Sat Feb 23, 2019 6:47 pm
Thought it was an emissions nipple for the tank breather to go into the sump and avoid fuel vapour entering the air. Californiae invention perhaps.
3 Re: Mystery Nipple Sat Feb 23, 2019 7:06 pm
Basic2
Looks like a wiring connector to a coolant sensor that's not used.
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
4 Re: Mystery Nipple Sat Feb 23, 2019 7:25 pm
For a K100 yes and for a K1100 it is connected to the cyclonic oil separator.K75cster wrote:Thought it was an emissions nipple for the tank breather to go into the sump and avoid fuel vapour entering the air. Californiae invention perhaps.
Good idea is to put the model and year in the signature section that way you can tell all without typing it each time.
6 Re: Mystery Nipple Sun Feb 24, 2019 12:29 am
It will be the tank breather that was put on to keep the numpties in California happy.
7 Re: Mystery Nipple Sun Feb 24, 2019 1:43 am
It was connected by a hose to the rear pipe of a pair of stub pipes descending from the rear underside of the tank. It was a flawed idea but apparently satisfied governmental Californicators, as Rick G has indicated. Slip a short piece of vent hose onto it, fold the hose then clamp it to the pipe. If you don't block that pipe, you'll need to put a sticker near it warning people that the crankcase contents is poisonous and they should not suck on the pipe.RicK G wrote:It will be the tank breather that was put on to keep the numpties in California happy.
Is there a hose on either of those pipes at the rear of the tank?
8 Re: Mystery Nipple Sun Feb 24, 2019 10:18 am
andy442
Thanks for the info. Sure sounds like something the commierades would do in this state . I'll just run a piece of hose to nowhere.
9 Re: Mystery Nipple Sun Feb 24, 2019 10:35 am
One of my bikes had a golf tee hammered into the stub on the front of the block. Seems to work.
10 Re: Mystery Nipple Sun Feb 24, 2019 11:45 am
What I've seen on a lot of Ks (and am guessing was done by dealers) is that the factory hose coming off it was snipped, folder over and zip-tied.
11 Re: Mystery Nipple Sun Feb 24, 2019 12:05 pm
It's easy to do, and makes sense too, go to Signature in your Profile. Add the bike's year and model, so everyone can see what's being asked about - no guesses.andy442 wrote:The bike is s 1988 k75s.
1977 R75/7-100, '93 K11/K12 Big Block, '95 R100 Mystic, '96 K1100RS, '98 K1200RS, '06 K1200R & '09 K1300GT. Projects: 1993 & '96 K1100RS, & 1st '98 K1200RS.
Similar topics
