1Back to top Go down   FS: 1985 K100RT $800 Empty FS: 1985 K100RT $800 on Sat Sep 21, 2019 5:53 pm
volador
volador
Not mine just compelled to post it up
Your fall/winter project awaits.
Probably an easy fix.
Good day
FS: 1985 K100RT $800 00K0K_7JSqXwOkPeL_600x450
https://newjersey.craigslist.org/mpo/d/matamoras-bmw-k100rt/6979463846.html
2Back to top Go down   FS: 1985 K100RT $800 Empty Re: FS: 1985 K100RT $800 on Sun Sep 22, 2019 10:59 am
Woodie
Woodie
1985 with ABS? be interesting to see what the year really is.  Has anyone ever retrofitted ABS to an early K?  Seems like that would be way too fussy and expensive a project.
1985 K100RT
52667
3Back to top Go down   FS: 1985 K100RT $800 Empty Re: FS: 1985 K100RT $800 on Sun Sep 22, 2019 11:40 am
ABS retrofit?  Let's see...
Front forks to mount wheel sensor
Hard brake lines to front actuator
Wiring harness with ABS wiring
ABS actuators with mounting hardware
ABS brake lines front and rear
ABS brain
Front wheel with ABS ring
Rear brake rotor with ABS ring
Late model instrument cluster
Relay box with ABS relays
Sounds like a lot of cash even if you get the parts on ebay.
I wonder if the title matches the frame number.
4Back to top Go down   FS: 1985 K100RT $800 Empty Re: FS: 1985 K100RT $800 on Sun Sep 22, 2019 1:35 pm
From looking at the small crappy pics:
1) The right side does have an ABS peg plate and rear ABS modulator.
2) The left side has no peg plate or front modulator.
Chances it's an 85?  Slim to none.
