1 Bellypan attachment frame Wed Apr 29, 2020 11:50 pm
ERasberg
Hi everyone,
After winter hiatus in Norway, I'm coming out of the woodwork again but with a start-up problem : My belly-pan "attachment frame" sheared its two left-side attachment points (see drawing), leaving the belly-pan dangling.
When I had disassembled everything, I realized that the drawing didn't match the bike setup.
The drawing shows 2 screws bolted straight into the engine block whereas I have 2 fat rubber grommets between the engine block and the "attachment frame" - like a shock absorbing buffer. The rubber grommet sheared in half (into two donuts with half the height) and now one half is stuck in the engine block. No screw actually went all the way through the grommet, it looks like it had one male end screwing into the engine block and one female facing the "attachment frame" side.
I believe I can remove the rubber grommet, my real question is whether this is a standard setup and if so, does anyone know the part number of this fat grommet that I need to replace ?
I hope the problem description makes somewhat sense.
Your input would be highly appreciated as I really like the look of the bike with the belly-pan on.
Best regards,
Einar/
Best regards,
Einar/
Present
1988 K100 RS SE - VIN# 0146971K100RS - 105,000 km
1998 R1200C
1971 R75/5
Previous
1999 Virago XV125
1981 R65
