1Back to top Go down   sold sold Empty sold sold on Sun Dec 08, 2019 4:09 pm
NoSprk
NoSprk
SOLD
2Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 5:24 am
For some strange reason I have 4 tank bags....seem to have one for each K.
But the one that came with my 83 K100RS does fit my 97 K1100LT...a try again?
1983 K100RS 0011171 Fricka 606 Alaska Blue 29,495 miles Damn K Pox Its a Bat outta Hell Now 36,188  miles
3Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 10:53 am
The K75/K100 tank bag bases have "hooks" on the sides that wrap around the seam of the tank - in front of the side/battery covers.  Since K1100s have side covers that go all of the way forward those hooks won't work on a K1100.
The K1100 (and K1 BTW) tank bag straps connect to these little brackets that attach to the tank.
sold sold R6Pm7LQ
4Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 12:49 pm
If you don't have the clips that attach to the ears on the tank it's no big deal.
I removed the ends of the straps and with a piece of plastic tube made two loops with parachute cord to go around the the ears on the bottom of the tank.  After over 30,000 miles the loops still work very well.  One advantage is that I can compensate for the stretching out of the elastic in the hold down straps by tightening up the loop.
sold sold Dscn3812
5Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 1:02 pm
Good workaround. (I would've used black paracord though. Very Happy)
6Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 1:41 pm
NoSprk
NoSprk
thanks guys. i found a factory k1100rs/lt base and will use it with this same style bag i have for my R100GSPD. i dont need two of the same bags. i found the clips from a european company and am hoping they will come through shipping them via another USA company.
'93 K1100LT '91 R100GSPD '73 R75/5
7Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 2:04 pm
Heads up: Although all of the Multivario tank bags look the same and may have the same part number they don't all have the same zipper between the base and tank bag - even among tank bags for the same model bike. I have several K1100 tank bags and they don't all mix-n-match. This is probably because they come from different years' production runs.
8Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 2:07 pm
NoSprk
NoSprk
@duck wrote:Heads up: Although all of the Multivario tank bags look the same and may have the same part number they don't all have the same zipper between the base and tank bag - even among tank bags for the same model bike. I have several K1100 tank bags and they don't all mix-n-match. This is probably because they come from different years' production runs.
thanks duck ill have to double check that.
9Back to top Go down   sold sold Empty Re: sold sold on Mon Dec 09, 2019 3:26 pm
Do check it because I also found that....so when I pack away a tank bag I pack the base inside it.
On the K1100 though I take off the side panels to fit the tank bag base to the tank in the same way as on the K100 and leave the 'ears' outside....looking at those photos the tank bag I got with the K1100 must be a K100 one as the hooks on the tank would mean the tank bag base would have to be shorter....I don't have those two hooks on my K1100.
