1Back to top Go down   Rear Master Cylinder Empty Rear Master Cylinder Fri Apr 17, 2020 3:12 am
larrikin
larrikin
I'm lookingf for a rear master cylinder for mt K100RS 1988 model.
Does any know if a master cylinder from an 85 model will fit?
Rear Master Cylinder Au-log11Rear Master Cylinder Au-log11
88 BMW K100RS
It increases my paranoia
Like lookin' at my mirror and seein' a police car
2Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Fri Apr 17, 2020 3:48 am
I've been running a $15.00 Au Chicom master cylinder since early 2017 with good results. Depending on the set up on your Brick you may have to get a hose made. They now come in black and I bought a second one as a spare.
See http://www.motobrick.com/index.php/topic,9364.msg116179.html#msg116179
3Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Fri Apr 17, 2020 4:17 am
Suzi Q
Suzi Q
The bore size changed a few years into production. I don't think anything else did and the change was just to improve the feel of the brake.
I find that the Motorworks website is (unintentionally!) useful for checking compatibility over different models and years. Wink
4Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Sat Apr 18, 2020 2:47 am
larrikin
larrikin
Thanks for the info
88 BMW K100RS
5Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Sat Apr 18, 2020 7:07 am
tinyspuds
tinyspuds
I have been running a Chinese one too for about 3000 miles very pleased with performance and price. Doesn’t take much to retrofit.
6Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Sat Apr 18, 2020 9:24 am
I've installed three, or maybe it's four, of the ChiCom master cylinders on my bikes over the past 3 years and put a total of well over 20,000 absolutely trouble free miles.
Putting one on my K75RT actually made it possible for the rear brake to actually slow down the bike!!!
7Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Mon Nov 28, 2022 7:51 pm
gravelsandwich
gravelsandwich
I've just installed this Chinese rear cylinder.
Rear Master Cylinder Rs111
Rear Master Cylinder Rs310
8Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Mon Nov 28, 2022 8:05 pm
It looks like you have used the reservoir supply hose that came with the master cylinder. Mine failed dramatically. I went to my local brake guy to get another piece of brake fluid rated hose. I showed him the failed hose and he said it looks like vacuum hose.
Rear Master Cylinder Reserv18
Rear Master Cylinder Reserv19
9Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Tue Nov 29, 2022 12:51 am
gravelsandwich
gravelsandwich
Yes it is the hose supplied. Thanks for the tip Martin, I'll replace it. I haven't had a chance to test it yet, I'm waiting on a banjo hose end adapter to complete the install. Cheers Liam.
10Back to top Go down   Rear Master Cylinder Empty Re: Rear Master Cylinder Tue Nov 29, 2022 1:05 am
I came very close to a disaster, I was about to go on a long trip and was doing a final check. I noticed a wet look to the reservoir hose so I decided to give it a wipe with a white rag. I just touched it very gently and the hose disintegrated and dumped brake fluid over the garage floor. If I had gone on the ride I possibly wouldn't have finished it as fluid would have ended up on my rear tyre. It pays to check and maintain your Brick.
