1Back to top Go down   Top case lock barrel Empty Top case lock barrel on Fri May 01, 2020 11:28 pm
GF Wollongong
GF Wollongong
Needed for a square BMW top box.
Have had to drill out lock and hoping to replace the barrel or the whole lock
Key definitely preferred
Hoping to avoid postage from Motobins
thanks
Guy
I do have some other parts if you wish to swap
2Back to top Go down   Top case lock barrel Empty Re: Top case lock barrel on Sat May 02, 2020 8:54 pm
I presume this is the 22L top box of which I have a wrecked one at home.
The only problem is I will not be back home for a couple of months.  Can you wait that long?
3Back to top Go down   Top case lock barrel Empty Re: Top case lock barrel on Mon May 18, 2020 4:58 am
GF Wollongong
GF Wollongong
Sorry for delay
Yes I can wait - it is not urgent
I am hoping to use it and thus remove the two side panniers when I am riding.
I have drilled out the barrel and can't see how it works - there seems to be nothing that disengages and re-engages the lock from the internal wire frame on the underside of the lid.
Anyway looking forward to hearing from you.
Regards
Guy
4Back to top Go down   Top case lock barrel Empty Re: Top case lock barrel on Thu May 21, 2020 3:31 am
GF Wollongong
GF Wollongong
I was lucky to get a replacement lock from a friend and am no longer in need of one.
So if anyone else needs one, perhaps get in contact with the link above.
Regards
GF
