1Back to top Go down   Flasher Unit  Empty Flasher Unit Thu Oct 28, 2010 4:10 am
Ned
Ned
Hi,
I am about to bid for a 1991 K1100 Flasher unit. Do you know if it will fit a 1986 K100?
Ned
2Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Thu Oct 28, 2010 4:45 am
Hi Ned,
Don't know off the top of my head but take a look on someone like Real OEM that has spare parts with the full exploded diagrams which gives part numbers and look both up if the part number is the same you have got the answer.
3Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Thu Oct 28, 2010 5:43 am
I just checked for you and both have the same reference #.
Happy Biding.
Flasher Unit  Frog15Flasher Unit  Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Thu Oct 28, 2010 6:46 am
Ned
Ned
Crazy Frog wrote:I just checked for you and both have the same reference #.
Happy Biding.
Thank you Bert Smile much obliged.
Ned
Ned
5Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Thu Oct 28, 2010 8:01 am
Ned
Ned
got one for $45 delivered. I figure that it will be a good spare if my current problem proves to be something else. My blinkers randomly stop working and regain full function again randomly. I can't find a pattern so I suspect that the flasher unit is playing up.
Stupidly I hesitated a few day ago, I could have got the whole set of relays for $50... oh well, live and learn.
Ned
6Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Thu Oct 28, 2010 10:13 am
japuentes
japuentes
Ned wrote:got one for $45 delivered. I figure that it will be a good spare if my current problem proves to be something else. My blinkers randomly stop working and regain full function again randomly. I can't find a pattern so I suspect that the flasher unit is playing up.
Hi there, I had a similar problem. The flasher unit has two relays soldered to the circuit board, the welds tends to crack and causes intermitent failures. Easy to fix.
Best regards
JAP
7Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Thu Oct 28, 2010 10:42 am
Thanks for the tip.
I guess Ned will be mad if he finds the soldering being the problem.
8Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Thu Oct 28, 2010 5:59 pm
Ned
Ned
You know I was toying with the idea to ask this earlier, but forgot. Yep, i will be peeved as I could have used the money for something else like an oil change, but what can you do? It is my daily ride and I want it back on the road asap Smile
Thanks JAP. I will check tonight.
Ned
9Back to top Go down   Flasher Unit  Empty Flasher Unit problem (SOLVED) Wed Nov 10, 2010 9:13 pm
Ned
Ned
A trap for young players :
1. my Flasher unit arrived, got changed, worked for about 10 sec and stopped, just like the old one. Sad
2 my first though was that I just wasted my money and time, but had to find the fault, so I got on with it.
3. looked at the interactive diagram in colour and couldn't find the problem as all usual suspects and plugs worked just fine.
4. decided to look at the fuse, and sure enough the fuse in question (#3 from memory) felt very loose in the receptacle.
5. wire brush cleaned all spades on all fuses and put the whole thing together.
6. it all works just fine now. So I quickly did a rego (MOT? or whatever you call it) check.
Yes, I did waste my money and time, but the fuse never entered my mind because the problem was INTERMITENT and fuses fail catastrophically. Oh, well. The moral of the story ... check fuses first! Also must invest in the ... you guessed it ...a can of DEOXIT! Smile
Ned
10Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Fri Nov 12, 2010 2:24 am
Hi Ned,
Bloody good on you for telling us what the problem was, a huge number of people would have said sod all so we all lose out by missing another bit of good knowledge learned.
11Back to top Go down   Flasher Unit  Empty Re: Flasher Unit Sat Nov 13, 2010 1:01 am
Ned
Ned
No worries,
I just hope that no one minds my bullet point summary. My attention span is that of a gnat, so quick summary suits me better.
Ned
Ned
