1Back to top Go down   Greetings from Finland  Empty Greetings from Finland Sat Jun 06, 2020 7:31 am
teuski
teuski
Hi guys!
I've had my '84 K100 for three years now and i' m really happy with it. It was an RS but the driving position was awful for a shorty like me. I swapped in a higher handlebar and got rid of the fairings. I now have a normal K100 radiator cover. I never seem to be content with the bike and always keep tinkering something. I have adventure tires on my bike and like to take it on gravel roads. I'm now waiting for a longer K1100 rear shock to try. I'm not able to flatfoot even with the original though...
I like cafe racer style and would like to do something like that to the rear end, but i want to keep the two-up capability and possibility for luggage boxes.
Considering all that i really should get a GS, actually a R1200GS is my dream bike but for now it's outta my budget...
Greetings from Finland  Img_2011
2Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Sat Jun 06, 2020 8:55 am
Bonzo
Bonzo
Greetings teuski  Greetings from Finland  177912
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
3Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Sat Jun 06, 2020 9:22 am
Welcome from Northern Ireland Very Happy
4Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Sat Jun 06, 2020 7:07 pm
Chocolate
Chocolate
@teuski wrote:… I'm now waiting for a longer K1100 rear shock to try. I'm not able to flatfoot even with the original though... …
First welcome here, man from Finland!
I’m not sure using a rear shock from a 4v for a 2v is a good idea. The angle for the drive shaft will change and that’s not good for the joint.
3cm more, 2Vs 350mm, compared to 4Vs 380mm.
Cheers from Germany
5Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Fri Jun 12, 2020 6:33 pm
teuski
teuski
Well people seem to use them a lot with scrambler builds without problems. I got the shock and tried it out. It got a little too high for me and both the sidestand and centre stand would need some mods to still be reliable. I decided to put the old one back. If i ever decide to make some more serious build, i'll think of it again...
6Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Fri Jun 12, 2020 10:36 pm
Welcome Teuski Smile
Greetings from Finland  Eu-log10  K1100RS/LT - R1200RT - R1100RS (RIP) - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S
7Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Sat Jun 13, 2020 4:03 am
brickrider2
brickrider2
Welcome from Idaho, USA  cheers
1996 K1100LT
8Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Mon Jun 15, 2020 6:10 am
edgeoftheworld
edgeoftheworld
Welcome!  I've got an 09 1200GS and an 87 R65 too.  The K bike is a nice complement to them.  I recommend getting both!
9Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Mon Jun 15, 2020 11:46 am
@teuski wrote:Hi guys!
Hi Teuski,
do you know what handlebars you used.
welcome to the forum.
Greetings from Finland  Ir-log11 88....May contain nuts!Greetings from Finland  Ir-log11
10Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Mon Jun 15, 2020 5:08 pm
teuski
teuski
Hi Teuski,
Thank you,
This is what i have:
https://www.ebay.co.uk/itm/292055420754
I'm planning to try raising it with 55mm risers but i need to get a longer brake hose.
I already moved the lunchbox more backwards and up by mounting the base to rearhandlebar bolts. I would have put it even more backwards on top of the handlebar mount but there is that reinforcement bar blocking the way.
Since the first pic i moved the headlight more up and tried on a little headlamp fairing. The shows it somehow. I'm waiting for a slimmer LED headlight unit to be able to move the fairing more to the rear so that it would fit flush with the lunchbox and hide it. Now that i think about it it would be much like the standard K100 fairing but without the HUGE indicators Smile I had that on in gold color before...
Any comments on the color of the bit? Should i keep it black or paint it gold like the rest of the bike?
Actually that color is not 100% what i like. I was expecting more copper than gold but it turned out very different from the color on the can Smile
Greetings from Finland  OboCoIF
11Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Wed Jun 17, 2020 11:02 am
To me, that looks fine in black. I like the main colour too.
12Back to top Go down   Greetings from Finland  Empty Re: Greetings from Finland Wed Jun 17, 2020 1:48 pm
tinyspuds
tinyspuds
Welcome. Sidecar Very Happy
