1Back to top Go down   K100 Rs café racer Neutral gear Empty K100 Rs café racer Neutral gear Fri Aug 21, 2020 4:17 pm
Roadstermac
Roadstermac
K100 Rs café racer Neutral gear F9a7c010
K100 Rs café racer Neutral gear 9c1bc310
Pleeease help. Jeje
Hi my name is Mike.
I have a k100rs and I’m now trying to connect de gear.
IMPOSSIBLE MISSION.
I have the 3 relays
too.
Does anybody exactly knows How to connect the 3 wires to neutral(mass) to 6 gears on my speedo? Please I’m getting crazy. K100 Rs café racer Neutral gear 7c538810
K100 Rs café racer Neutral gear Dc15c610
K100 Rs café racer Neutral gear 1428f910
2Back to top Go down   K100 Rs café racer Neutral gear Empty Re: K100 Rs café racer Neutral gear Fri Aug 21, 2020 5:49 pm
Read this thread:  https://www.motobrick.com/index.php?topic=8964.0
The pin numbering on the diagram matches common pin numbering on automotive relays:
85 & 86 = relay coil
30 = common terminal
87 = normally open terminal
What specifically is driving you crazy about this circuit?
BTW, this circuit will only detect neutral gear. It will not allow you to indicate any other selected gear on your aftermarket gauge, if your gauge has that capability.
3Back to top Go down   K100 Rs café racer Neutral gear Empty Hi there. Thanks Robmack Sat Aug 22, 2020 1:46 pm
Roadstermac
Roadstermac
@robmack wrote:Read this thread:  https://www.motobrick.com/index.php?topic=8964.0
Thanks for your reply.
The thing is that I have that circuit from here
https://c59rstore.com/es/acewell/960-velocimetro-y-tacometro-acewell-ace-ca085.html?search_query=Neutral&results=13
And I think it’s Makes the same As the 3 relays, it works but, when I change to gear one or any other, the neutral downs disappear, I’m not able to connect the gears Coming from the New speedo to appear on the screen, Do we have to have all the neutrals coming from the motorbike grounded or connected between?
Where do we have to connect the blue wire, only to neutral from the  new speedo? How can we energised the cable coming from the starter?
And the last one, how does the speedometer works to show the gears in the screen?
Many questions jeje.
K100 Rs café racer Neutral gear 3d23d310
This is the speedo
Qiilu Universal Motorcycle Digital Colorful LCD Velocímetro Cuentakilómetros Tacómetro con Sensor de Velocidad
https://www.amazon.es/dp/B07B7M8JK1/ref=cm_sw_r_cp_api_i_q4uqFbRZXM1AE
Thanks so much
4Back to top Go down   K100 Rs café racer Neutral gear Empty Re: K100 Rs café racer Neutral gear Sat Aug 22, 2020 2:48 pm
@Roadstermac wrote:The thing is that I have that circuit from here
And I think it’s Makes the same As the 3 relays, it works but, when I change to gear one or any other, the neutral downs disappear, I’m not able to connect the gears Coming from the New speedo to appear on the screen . .
That device you bought only shows Neutral and enables starting in Neutral. It is not designed to show any other gear on the speedometer display. Which Acewell model do you have?
1995 K75 81,000 miles
K100 Rs café racer Neutral gear Usa-lo10
5Back to top Go down   K100 Rs café racer Neutral gear Empty Re: K100 Rs café racer Neutral gear Sat Aug 22, 2020 2:54 pm
As I said in my last sentence in the post I made above, you cannot expect this product you bought to be able to indicate each and every gear you select in the gearbox.  It's purpose is only to detect the neutral gear.  When you select any other gear on the bike, the neutral light on your gauge will extinguish, as you point out.
If you want to have the ability to show the gears on the gauge as you select them, then you  will need a different product, either a Marulabs BEP 3.0 or a Tenet. Those two products have digital logic in them to drive the display capability of your gauge.
I'll answer your question about the blue wire and about energizing the bike to start.  If you look at the diagram I linked to in my first reply, you will note that there is a diode.  You will have to add this same component on your bike in addition to the relay product you bought and installed.  A good diode to select will be a 1N4001. The cathode of a diode is indicated on the body of a diode by a white stripe. The lead closest to the white stripe is the cathode; the other lead is the anode. Connect the anode of the diode to the blue wire coming out of the relay and the cathode of the diode you will connect to the Black/Green wire that comes from Pin 5 of the OEM cluster connector.  This will solve your problem, allowing you to start the bike when it is in neutral.  In the meantime, to start your bike, you will have to pull in the clutch handle until you can make this modification to your bike.
6Back to top Go down   K100 Rs café racer Neutral gear Empty Re: K100 Rs café racer Neutral gear Sat Aug 22, 2020 3:23 pm
Roadstermac
Roadstermac
@robmack wrote:As I said in my last sentence in the post I made above, you cannot expect this product you bought to be able to indicate each and every gear you select in the gearbox.  It's purpose is only to detect the neutral gear.  When you select any other gear on the bike, the neutral light on your gauge will extinguish, as you point out.
Thanks. I’ll do it.
im glad to ear you.
I’ll try to do it these days.
Thanks Rob
7Back to top Go down   K100 Rs café racer Neutral gear Empty Thanks Laitch Sat Aug 22, 2020 3:27 pm
Roadstermac
Roadstermac
I’m glad to ear you.
The problem is I can’t enable the starting in neutral.
Thank U so much.
