Dangerous Brian
Dangerous Brian
I’ve now built my K100 trike but up graded the front brakes. I now need a master cylinder with the bigger capacity.
Dangerous Brian
1985 K100RT Trike - with FZ750 forks..... and Reliant axel Very Happy
'83 K100 upgraded to K100RS spec, '87 K100RT
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
Dangerous Brian
Dangerous Brian
It has to be the K1100 because that has a 20mm cylinder. The K100 has a 13mm so it is not moving enough fluid. Also, if I can get the K1100 unit I’m told the K100 switches fit straight on.
Dangerous Brian
@Dangerous Brian wrote:It has to be the K1100 because that has a 20mm cylinder.
If you scroll down at Dai's link you'll find an offer of used K1100 front master cylinders if available, and a link to new stock also.
1995 K75 77,000 miles
Wanted - K1100 front brake master cylinder  Usa-lo10
Aye - should have said 'item 7'.
The 20mm master cylinder isn't only used on K1100...
Part number 32 72 2 352 165 is also used on the models listed below, except R1100S. Keep in mind you'll also need the K11 style throttle tube and an appropriate length accelerator cable from a K11.
The links above will take you to the various realoem.com/bmw catalogues so you can peruse the diagrammes of the model you choose.
Sometimes I lie awake at night, and I ask, "What can I do to keep my life from going by so fast?" Then a voice comes to me that says, "Try slowing down at the corners."
~Charlie Brown
1970 R60/5, '77 R75/7-R100, '85 K100'87 K75C, '87 K100RS, '93 K11-K12 Big Block, '93 K1100RS, '95 R100-Mystic, '96 K1100RS, '98 K1200RS, '00 K1200RS, '02 K1200RS, '03 K1200GT, '04 R1150R'04 R1150RT, '05 K1200S, '06 K1200R, '07 K1200R, '09 K1300GT & 2013 R1200RT-Polizei  - Beemers owned still or sold.
moriarti
moriarti
Hi,all sorry to jump in ,but,is it possible to reduce the height of front brake reservoir.If so how? and by how much??  scratch Mabey an old fart moment on my part,im sure someone will correct me Wanted - K1100 front brake master cylinder  161205
1984 k100 rs red/black VIN  0004449
@moriarti wrote:Hi,all sorry to jump in ,but,is it possible to reduce the height of front brake reservoir.If so how? and by how much??  scratch Mabey an old fart moment on my part,im sure someone will correct me Wanted - K1100 front brake master cylinder  161205
Put lower handlebars on it?
~Charlie Brown
moriarti
moriarti
Very Happy Very Happy see old fart moment
